December 27, 2024 at 9:22 am in reply to: Unable to communicate with the device [4] TestDev because connection is not est #15848
Possible cause is that the communication channel is not configured. Please provide screenshots of the communication line main options.
You can set directories in the archive properties.December 26, 2024 at 8:45 am in reply to: How to control LED flashing through the digital output(DO) port #15844
MikhailModeratorSo, you can send a command from Rapid SCADA to the device. Commands can be send using the Administrator application and the web interface.
December 26, 2024 at 8:43 am in reply to: Unable to communicate with the device [4] TestDev because connection is not est #15843
Please provide a communication line log.December 25, 2024 at 12:12 pm in reply to: How to control LED flashing through the digital output(DO) port #15839
Have you configured communication between the DO module and Rapid SCADA?
*.scss files are complied to *.min.css. You should change *.min.css.
CSS files are located in ScadaWeb\wwwroot\css
Use the developer tools in the browser to find a certain CSS file.-
This reply was modified 1 year, 9 months ago by
Plugin for event acknowledgement should be PlgMain.
The notification panel width is specified in CSS files.
MikhailModeratorHi Rodrigo,
Your question is about MQTT, not related the current topic of displaying strings.
Please start a new topic to discuss the question. Provide screenshots of the MQTT configuration and logs.
MikhailModeratorThe application is not ready, Try again later
Check ScadaWeb.log and ScadaServer.log for the error details.
MikhailModeratorIn that case, does the previous password work?
The MQTT client driver supports only numbers.
If channel 101 has length = 3, there are shadow channels 102 and 103 are created by Server.
You should not use channel numbers 102 and 103 explicitly in the Channels table.
Your description is correct.
I suggest to compare Modbus packets sent by Rapid SCADA and the other software. -
