Forum Home › Forums › Understanding the Software › reference lines of Chart Pro
- This topic has 6 replies, 2 voices, and was last updated 2 years, 4 months ago by
July 16, 2024 at 12:48 am #14942
grhsc
ParticipantI only select one tag as the curve of the trend chartpro, can I set the max and min reference lines? For example, if my trend is voltage, I want to add the max/min voltages to see if the current voltage is within the appropriate range.
July 16, 2024 at 9:19 am #14950
MikhailModeratorIn this case, create 2 extra channels, max and min. Set them as limits of the 1st channel (see this page). To display them on a chart, you need to select them manually or display chart as a view with predefined channels.
July 16, 2024 at 10:35 am #14954grhsc
ParticipantI don’t quite understand what you mean “ create 2 extra channels”
Do I need to create it in the channels menu or in limits?
I remember that the contents of channels are all from the real communicator, and I don’t quite know how to create extra channelsCan you give me more guidance please?
This reply was modified 2 years, 4 months ago by
grhsc.
July 17, 2024 at 12:27 pm #14972
MikhailModeratorCreate 2 channels of the Calculated/Output type in the Channels table.
Specify their numbers in the Limits table in a limit row.
Display the created channels in a table view.
Then provide screenshots.July 18, 2024 at 7:58 am #14980grhsc
ParticipantI can create 2 channels of the Calculated/Output type in the Channels table, but I don’t know how to set their values to constants (such as voltage max = 400V and min = 320V
https://drive.google.com/file/d/14FRlbuHy8oGxh-WBX2e3ogpGmoZC3wHA/view?usp=drive_link
Also, I can’t specify numbers in the Limits table, I can only specify what I set in the limits tab
https://drive.google.com/file/d/1xe5QxEZ95yp3YXbzdZkE2pBj9TzH146L/view?usp=drive_link
I think I must have made a mistake somewhere.
July 18, 2024 at 8:05 am #14981grhsc
Participantby the way, I would like to provide suggestions on this topic.
The current method of creating two channels is a compromise. It requires saving these two meaningless channel values in the database. If many variables need max/min and have different ranges, this should not be a good method.Since high and low are already defined in limit, can you add a setting in the parameter file of chartPro to display/enable high and low limit values? Would this be a good idea?
https://drive.google.com/file/d/1LvIvNQ8oYfkXLEKgl1ETJqWX0aqrcK6N/view?usp=drive_link
July 18, 2024 at 10:01 am #14984
MikhailModerator> The current method of creating two channels is a compromise. It requires saving these two meaningless channel values in the database.
If limits can be changed by a user, channels are not meaningless. In general, I agree with you, it would be a useful feature to display limits on chart.Specify
SetData()output formula for min and max channels. And create a new limit record for the channel. -
