Viewing 15 posts - 61 through 75 (of 6,403 total)
  • in reply to: ModArcPostgreSql configuration #18215
    By default ScadaInstanceConfig.xml contains credentials for the user/password postgres/postgres
    Try using the default version of ScadaInstanceConfig.xml and set the above login and password for the database.
    in reply to: Setting up events #18212
    Generating events is implemented here
    Please provide a screenshot of the channel event mask that causes unnecessary events.
    in reply to: Setting up events #18207
    When a device restarts, or when communication is lost and then restored, I receive a flood of “Defined” events
    If the “Channel is undefined” checkbox is not set in the channel’s event filter, I expect that such Defined/Undefined events should not be generated. Could you check please?
    in reply to: Where is Administration Application #18198
    in reply to: PlgMimPipesJP #18197
    Published at https://rapidscada.net/store/Module/en/PlgMimPipesJP
    If you upload the above video on YouTube, we could include it in a playlist in our public channel. This will help inform users about the new plugin.
    in reply to: Mqtt publisher #18196
    Why is the value 0? I wrote the value in the “send command”
    Please provide screenshot of the settings, and a command that was sent.
    in reply to: Mqtt publisher #18195
    MQTT Publisher Driver writes each channel to it’s own topic. It cannot write 2 channel in the same topic, e.g., { “humidity”:12, “temperature”:7 }
    Please clarify if you use MQTT Client or MQTT Publisher Driver?
    in reply to: Event archive vs. alarm events in Rapid SCADA 6 #18193
    Using Auto Control Module, you can create a data change trigger and create new events by that trigger having the different channel number. It may work if the amount of channels is not too big. Otherwise, it is not handy to configure.
    • This reply was modified 4 months ago by Mikhail.
    in reply to: Event archive vs. alarm events in Rapid SCADA 6 #18192
    As a workaround you could write data to PostgreSQL with help of DB Export Module. It also can write data on change.
    in reply to: Event archive vs. alarm events in Rapid SCADA 6 #18191
    An event contains the Severity field.
    The ScadaWebConfig.xml contains the EventArchiveCode option that defines the source for events displayed in the bottom panel on the web page. But there is no filter options for that panel. All events from the specified archive are displayed there. It can be an idea for future improvements.
    in reply to: How to implement on-demand reading? #18186
    As written above you need to split Modbus parameters into several devices (in terms of Rapid SCADA).
    in reply to: How to implement on-demand reading? #18185
    This is possible.
    In Communicator, set the Poll only on command checkbox for the device.
    To do a poll, send a command with the code App.Comm.PollDevice and the device number as a command value.
    in reply to: Unable to use Exact in TimeDetailing in ElasticReport #18184
    That’s right.
    Dear Prabhu,
    1. Please provide corresponding screenshots and logs. I’ll be glad to help you figure out the cause.
    2. Timestamps are accurately stored in the archive, but are truncated to the second when output. Unfortunately, I can’t provide any guidance on the implementation timeline. If you need it urgently, we can develop a separate report under the contract.
    in reply to: Using the MQTT client driver, an error occurred. #18177
    The *.js files should be located in your project among Communicator configuration files. Also specify the short file name in the device properties. The script example is here.
