Regarding Map Plugin Data Integration from SQL Database Forum Home › Forums › Installation Issues › Regarding Map Plugin Data Integration from SQL Database Tagged: Get Data from SQL Database, Map Plugin This topic has 3 replies, 2 voices, and was last updated 9 months, 2 weeks ago by Mikhail. Viewing 4 posts - 1 through 4 (of 4 total) Author Posts November 25, 2025 at 11:02 am #17340 modivirParticipant please confirm whether data can be fetched directly from our SQL database and displayed on the Map View interface. Kindly clarify: Is direct SQL database integration supported? Can the data be displayed in real-time or via scheduled synchronization? What integration method is used (API / direct connection / middleware)? Are there any specific database version or configuration requirements? November 26, 2025 at 10:39 am #17344 MikhailModerator Hello, To fetch data from the DB use Database Import Driver. Then display those data on by the Map plugin. The web application of Rapid SCADA uses its own web API. November 26, 2025 at 11:05 am #17346 modivirParticipant Hi, Will it show real-time data or schedule synchronization? November 27, 2025 at 11:35 am #17347 MikhailModerator Hi, I suggest to download and try. Author Posts Viewing 4 posts - 1 through 4 (of 4 total) You must be logged in to reply to this topic. Log In Username: Password: Keep me signed in Log In
