Viewing 15 posts - 691 through 705 (of 6,387 total)
  • in reply to: Not getting to view as a web page #16264
    Access to the log files is denied. Please make them public.
    in reply to: schemeeditor doesn’t launch at all – windows11 #16263
    I see under the “Instance Status” it says webstation “Status not supported” Can it be relevant?
    It’s not relevant. It just means that the app does not provide status.
    I suggest to check events in Windows Event Viewer. If an app accidentally crashes, the OS writes some info there.
    Also try to deploy a new virtual machine using Hyper-V or VMware and install the editor from scratch.
    in reply to: Not getting to view as a web page #16259
    Please provide a screenshot of the error by posting a link to Google Drive or other image hosting.
    Also check the ScadaWeb.log and ScadaServer.log files.
    in reply to: schemeeditor doesn’t launch at all – windows11 #16258
    When the editor starts correctly, ScadaSchemeEditor.log contains
    2025-03-25 12:50:42 <PC><user><ACT> Initialize common data of Scheme Editor
    2025-03-25 12:50:42 <PC><user><ACT> Load components from files
    2025-03-25 12:50:42 <PC><user><ACT> Components are loaded from the file C:\Program Files\SCADA\ScadaSchemeEditor\Web\bin\PlgSchBasicComp.dll
    2025-03-25 12:50:43 <PC><user><ACT> WCF service is started
    The editor uses WCF, so you may need to enable it as shown here.
    The editor opens TCP port 10001. Using TcpView make sure that the port 10001 is not used by another application.
    in reply to: Webstation issues on Win11 #16255
    When an error occurs, the details are written in ScadaWeb.log. Please check the log file for additional info.
    in reply to: Webstation issues on Win11 #16253
    ScadaWeb.log is OK.
    Errors like “Dictionary file not found” are not critical.
    What do you get when open http://localhost:10008/ in browser?
    Would you be able to explain the process of how the data from the Communication lines is transferred to the WebStation?
    The Webstation app connects to the Server app using TCP port 10000 and requests data.
    in reply to: Webstation issues on Win11 #16248
    Screenshots of the settings and results would help to solve the issue.
    in reply to: DrvParserTextJP #16247
    The driver has been added to Store
    https://rapidscada.net/store/Module/en/DrvParserTextJP
    in reply to: Table View Invalid DateTime Error #16238
    Please open the browser tools (F12), select the Network tab, and make screenshots of the HTTP request details.
    in reply to: DrvParserTextJP #16236
    Thank you 🙂
    in reply to: Web Station Error 500 #16231
    I keep seeing in the log that the Webstation is stopped. Now what?
    This is a normal behavior. If the web application has not been used for some time, it is stopped. When you open it again, it will be started. You can see than in the log file.
    in reply to: Web Station Error 500 #16230
    How can I totally uninstall the program and servers so that I can install it again?
    Usually it’s reinstallation needed to fix an issue.
    Website with the same name exists and Application pool item already exists.
    How so I deal with this, please?
    You can delete the pool and website manually in the IIS management console. If you are not sure, provide screenshots.
    in reply to: The page transitions are slow #16229
    Could you provide a screenshot or video?
    in reply to: Web Station Error 500 #16223
    Check the above.
    in reply to: Average value from 5 last values #16222
    May be you should set an input formula of the channel 145 to blank, and try again.
