Viewing 15 posts - 646 through 660 (of 6,387 total)
  • in reply to: information of the Archive #16379
    Likely, the directory that are set by default does not exist. Choose the correct directory by clicking the Browse button.
    in reply to: information of the Archive #16378
    Please check the selected “Trend table directory”. Does it contain data files?
    Can you view historical data via the web interface?
    in reply to: Configuring DrvMqttPublisher #16377
    MQTT Publisher sends data tag by tag. Payload format is configurable. I suggest to try. It does not require much efforts.
    in reply to: XML Content Translator for SCADA 6 #16372
    Thank you!
    I will try to merge it, and write here when completed.
    in reply to: Configuring DrvMqttPublisher #16371
    No, unfortunately. Set up intuitively. Write here in case of issues, providing screenshots.
    in reply to: XML Content Translator for SCADA 6 #16367
    In the next release zh-Hans will be added to the drop-down list. Do you have a script to rename all the files in the translation back to *.zh-Hans.xml?
    in reply to: XML Content Translator for SCADA 6 #16366
    This line of code filters the culture list. May be all cultures should be added to the list without any filtering.
    in reply to: information of the Archive #16365
    It looks like there is not data in the archive.
    Try opening the default archive written by the HelloWorld project.
    in reply to: information of the Archive #16361
    Use the TrendTableViewer utility to view data.
    in reply to: Event marker not found #16360
    First of all, we need sample data to reproduce the issue.
    Please do the following:
    1. Save the damaged file.
    2. Make sure that new events cannot be added to that certain damaged file.
    3. Share the damaged file using a cloud drive, so we can reproduce the issue.
    in reply to: Register reading with Modbus TCP #16359
    Try the Modbus parser https://rapidscada.net/modbus/ to find mistakes in requests.
    in reply to: XML Content Translator for SCADA 6 #16357
    I noticed that the culture name of the translation was changed from zh-Hans to zh-Hans-CN. The second is a region-specified culture.
    Could you please clarify what the difference is from a user experience perspective?
    What caused the change?
    • This reply was modified 1 year, 5 months ago by Mikhail.
    in reply to: Configuring DrvMqttPublisher #16353
    There are 2 ways to publish data via MQTT:
    1. Using the DrvMqttPublisher driver. Use this way to publish data of the selected channels.
    You should select the MQTT type of communication channel. Add a device, and set up the device’s properties.
    2. Using the DrvDsMqtt driver to create an MQTT data source. It’s more handy when you need to publish all data of the specified devices.
    Try to configure it intuitively, and publish screenshots if some settings are not clear.
    in reply to: Register reading with Modbus TCP #16352
    This video may help.
    If you add links to the screenshots of your settings and data, it would be useful to resolve the questions.
    in reply to: Scada webstation not getting open #16344
