Viewing 15 posts - 6,271 through 6,285 (of 6,403 total)
  • in reply to: "Unknown DLL" after upgrade #419
    Hi Bret,
    Great, you guessed it ) In the new version of SCADA-Communicator device driver DLL is independent of a connection type. Special software layer named Connection channel establishes and manages the connection.
    You tuned up SCADA-Communicator almost correct, but in your case you shouldn’t define IP address in the properties of the connection channel. Do it in Call Number field of a device like before.
    in reply to: Any questions about Rapid SCADA and Raspberry Pi #415
    You definitely right.
    After configuring using Windows you should copy the content of the follownig folders:
    C:\SCADA\BaseDAT
    C:\SCADA\Interface
    C:\SCADA\ScadaComm\Config
    in reply to: "Unknown DLL" after upgrade #413
    Is there Unblock button in the DLL properties like shown here?
    in reply to: "Unknown DLL" after upgrade #412
    Hi Bret,
    Did you install Rapid SCADA 4 Release 4?
    Please, describe the sequence of your installation and upgrade steps.
    in reply to: Advice required for setting up a basic system #411
    Hi Bret,
    I think, the reason of the issue is listed in the main log of Communicator C:\SCADA\ScadaComm\Log\ScadaCommSvc.log
    in reply to: Modbus addressing size #408
    OK, no problem )
    in reply to: OPC UA #404
    At the current time, Rapid SCADA supports only OPC DA and OPC AE specifications.
    in reply to: Advice required for setting up a basic system #402
    Hi Bret,
    If Cewe provides its own utility that request devices, we can sniff data exchange and realize what should we do.
    First, download and install the full package. Then download http://rapidscada.org/download/scada_4.5_update.zip and overwrite files in C:\SCADA\ScadaComm folder. If you find any bugs, post them in a separate topic.
    in reply to: Code for Trend #401
    When you click an icon in a table view, a chart will be shown.
    The same effect if you set Action property of a scheme element to “Draw diagram”.
    Component for Charting has additional functions such as scaling, displaying of multiple charts and choosing the period (v4.5+).
    in reply to: Rapid Scada not running on Web Browser due to 404 not found error #398
    admin / 12345
    guest / 12345
    in reply to: Code for Trend #397
    What are you going to do?
    in reply to: Ethernet/ip #394
    Every device supports its own application layer protocol via TCP/IP. For example, Modbus TCP which is the most popular.
    Hello Dejan,
    Thanks for the info.
    In addition, if IIS was installed after .NET, it is required to integrate them by executing aspnet_regiis.exe -i
    in reply to: Export data module manual exist? #389
    I think, it works as expected.
    Export current data error occurs because you send the same data twice.
    Export archive data is executed, for example, when you select Generator in SCADA-Server and send archive data.
    Current and historical data are stored in the same data table in case of using SQL from the manual.
    Dejan,
    Your Windows Features screenshot seems OK.
    What is the error page at the current time?
