Viewing 15 posts - 5,971 through 5,985 (of 6,387 total)
  • in reply to: Changing Table Colors, and event line color #1097
    You can easily the find the answer with help of Chrome. Press F12 and find the element by a mouse. Chrome displays the css file and line number.
    I recommend not to waste much time, because the web app will be totally redesigned.
    in reply to: Rapid SCADA on Orange Pi 2 plus #1096
    First of all, let’s make sure about the reason. Please write about the result after changing localization.
    in reply to: Export data module manual exist? #1093
    The manual is inside the installation package. The file name is Doc\dbexport_en.pdf
    Try using database model and scripts from the manual.
    in reply to: Modbus TCP multiple connections slow #1090
    I think it will be good idea to implement connection timeout. It will be done in a one of the future version of Rapid SCADA. Also this work can be accelerated on commercial basis.
    in reply to: Modbus TCP multiple connections slow #1089
    As an option you can split polling into several communication lines to communicate in parallel.
    How long does it wait if connection can’t be established?
    in reply to: scada server (state: error) #1088
    Look for the cause in C:\SCADA\ScadaServer\Log\ScadaServerSvc.log
    in reply to: Rapid SCADA on Orange Pi 2 plus #1087
    The cause that Mono can’t compile the line 79
    initialCmdVal = 0.0;
    that is shown in ScadaServer/Log/CalcEngine.cs
    in reply to: Rapid SCADA on Orange Pi 2 plus #1086
    Do you use comma as decimal separator?
    I think the most simple way to switch location and language back to English and check whether error disappear or not.
    in reply to: Rapid SCADA on Orange Pi 2 plus #1082
    Such error appears on Germany localization because of Mono bug. What OS culture do you use?
    in reply to: Rapid SCADA on Orange Pi 2 plus #1079
    Look at C:\SCADA\ScadaServer\Log
    What are in log files?
    I strongly recommend to use RAM drives for log folders in case of using SD card.
    in reply to: Excel Exporting #1074
    in reply to: Modbus Byte Order #1073
    Thanks for the info.
    in reply to: I cant see Scada Comunicator window #1072
    I did not know how to install only ScadaWeb
    You can choose checkboxes in the installer.
    Anyway you have installed it 🙂
    in reply to: Dynamic Graphics Formation #1071
    Dear Tarak,
    If you mean showing sliders, you should create a set of images using your favourite image editor in PNG or JPG format. Each image will contain their own level. Then open SCADA-Scheme Editor and use Dynamic picture component. Configure Conditions property of the component to show an image according to input channel value. Don’t forget to specify Input channel property.
    in reply to: Modbus Slave Simulator #1067
