Viewing 15 posts - 5,926 through 5,940 (of 6,387 total)
  • in reply to: Modbus Data Recorder Registers #1216
    What is load profile?
    in reply to: Managing events #1212
    Based on your ideas I can generate inherited ideas 🙂
    in reply to: Managing events #1211
    Thanks for the ideas!
    To view all daily events, you should export them to Excel.
    Checked events have the same behavior as others.
    users should not have access to that tool.
    Users must not have access to the server file system.
    in reply to: Managing events #1209
    How/where could I see/configure more than the last 9-10 events?
    Use SCADA-Web Configurator -> Visible events count
    How can I easily do an event sent an email ? Do I need to create a rule on Autocontrol for each channel
    Yes, you should create a rule. If it’s enough to receive the same message, you can create some kind of aggregation channel. In case of using limits, you can specify trigger on status.
    Where are they stored (in case you need to delete ie… 100’s) ?
    See directory settings of SCADA-Server.
    in reply to: Service – create channels: data was truncated ?? #1206
    Fixed. Thank you for the bug report.
    in reply to: RapidScada on Linux #1205
    Yes. Download Rapid SCADA Mono. Manual is made for Debian.
    But in the current version schemes are not accessible. The new web app is OK.
    in reply to: New Web App Idea? #1203
    Hmm in the place of the event window? Or alongside the event window?
    Custom Data window. Events closes when another window is shown.
    In any case a minimize button for the new window if there is one and a minimize button for the event window would be nice.
    It exists – the gray circle with arrow.
    the event window will automatic open again when a new event happens
    Notifications like Skype would be nice, but not in beta version.
    in reply to: Using a Virtual Server #1198
    in reply to: Using a Virtual Server #1197
    can i run RapidScada in a virtual server in Azure or Amazon?
    Yes. Talking about Azure, you have to use virtual server for SCADA-Server and SCADA-Communicator and you can use Web App for SCADA-Web.
    Does the licenses for ACM (Automatic Control Module) and Chart Pro/List work on those?
    Yes.
    If you try Amazon, please tell about the experience.
    in reply to: New Web App Idea? #1195
    Instead of “Ошибка сервера в приложении ‘/Scada5′”
    in reply to: ModAutoControl: send email with channel values #1192
    in reply to: ModAutoControl: send email with channel values #1190
    This checkbox works for command triggers only.
    The feature of inserting dynamic text is not supported by Auto control module for now. It is in the plans.
    The specified feature will be possible when the module can send command via output channels. In this case using a formula you could generate any text.
    Thank you 🙂
    This is not a bug. The directory of the view set must be correct. It can be set by SCADA-Web Configurator. I’m used edit files.
    in reply to: Service – create channels: data was truncated ?? #1185
    I will check.
    Is there any additional info in C:\SCADA\ScadaAdmin\ScadaAdmin.err ?
    in reply to: Several days/channels graphs are generated slooooowly #1182
    I’m sorry to say that I don’t agree with your decision on keeping with binary data but… OK.
    May be the source code should be refactored to allow switching the storage.
