Viewing 15 posts - 5,881 through 5,895 (of 6,387 total)
  • in reply to: Error in TCP modbus simulation #1326
    The formula is applied in SCADA-Server. That’s why you can’t see a result in Communicator. You have to configure displaying data by SCADA-Web app and you will be able to see calculation results.
    in reply to: Communication is not established with MODBUS simulator #1321
    Do the both communications the old and the new work in parallel?
    Post a piece of communication log, please.
    in reply to: Error in TCP modbus simulation #1319
    You should use a formula of the appropriate input channel in SCADA-Administrator application.
    The formula below will be useful. Add it in the Formulas table and use in the formula of the input channel.
    public double GetByte(double val, int n)
        UInt64 uintVal = (UInt64)val;
        return (uintVal >> (n*8)) & 0xFF;
    The formula of the input channel is like
    (((256*GetByte(Cnl,3))+GetByte(Cnl,2))+(GetByte(Cnl,1)/256)+(GetByte(Cnl,0)/(256*256)))/10
    I haven’t tested it.
    in reply to: Communication is not established with MODBUS simulator #1318
    Mudbus TCP usually uses 502 port. Try setting up the communication channel. Use TCP client channel type.
    in reply to: Error in TCP modbus simulation #1314
    If you’d like to switch off SCADA-Server, you should uncheck Use SCADA-Server option in Communicator.
    in reply to: Error in TCP modbus simulation #1313
    You are requesting the same when the communication is OK and when it’s broken.
    It means that something wrong with a simulator application. May be some settings of the simulator were changed, e.g. device address.
    in reply to: request sequensce confusion #1312
    active and bound option again in request sequence, while it is already taken in line parameter.
    Unchecking Active disables a whole communication line or a device.
    If Bound is true the data from a communication line or from a device are sent to the SCADA-Server. Unchecking Bound of a communication line is the same as unchecking this parameter of each device.
    significance of timeout and delay
    Timeout is the time while you are waiting for the responce from your device.
    Delay is the delay after receiving data before the next request.
    They should be set experimentally to provide stable communication.
    delay after request cycle
    Additional delay after requesting all the devices of the communication line.
    in reply to: OPC Server in RapidSCADA #1308
    For now Rapid SCADA works as OPC client, not as OPC server.
    May be you can use DB, such as MySQL, for the integration purpose?
    in reply to: Does RapidScada Support HTTPS #1306
    Yes. HTTPS is supported and configured by IIS. You should read about using certificates in the Internet.
    To enable HTTPS in Rapid SCADA, find all the web.config files in C:\SCADA\ScadaWeb and look for the commented blocks by the word “https”. You should uncomment them.
    in reply to: WCF service error #1303
    Read this thread.
    The new version of the web app is under construction: http://forum.rapidscada.org/?topic=new-web-app-idea/#post-1281
    in reply to: Newbie #1301
    This article helps you to connect to OPC server.
    I recommend to test KpGS828.dll from the driver pack too. If it works, it’s preferable than OPC because of reliability.
    English version of the driver pack will be released when it includes more than 1 driver useful for the wide range of countries. Thanks to Washu Hakubi about the notice about ASCII encoding of readme.txt
    in reply to: Newbie #1295
    May be you should ask a manufacturer whether GSX4-MS is able to communicate with a PC using Modbus protocol as a Modbus gate (example). In this case you can use Modbus register map which should be included in a manual of the sensors.
    in reply to: Newbie #1294
    This is not Modbus, unfortunately. It looks very similar to the protocol used by GS828 logger. Try using the driver pack. Then translate readme.txt and install it.
    You don’t need to configure a template, just configure polling.
    Do you need inputs and outputs of GSX4-MS? If not, it overfunctional and complex for your task for my opinion. Ethernet-RS-485 converter like this one is enough.
    in reply to: New Web App Idea? #1291
    Try using Chrome of Firefox.
    The standard Android browser may be outdated. I will add browser validation and displaying message whether a browser is not supported.
    in reply to: Newbie #1289
    Does GSX4-MS use Modbus protocol to communicate with PC and work as a gate between your devices and server? First of all, you need to realize what kind of protocol (over TCP) is used for interacting with GSX4-MS.
    If it uses Modbus, you should configure Rapid SCADA as described in the article http://rapidscada.org/connecting-devices-using-modbus-protocol/
