Viewing 15 posts - 5,506 through 5,520 (of 6,388 total)
  • in reply to: Links in the Scheme #2203
    Please clarify your question.
    in reply to: Dashboard launch prompt Insufficient Right for chart #2202
    I suppose, you should install and switch on the Chart Pro plugin. It is used by Dashboard if a chart contains more that 1 input channel.
    in reply to: Alien LiveChart or Gage #2195
    The example of using the API.
    in reply to: Alien LiveChart or Gage #2194
    Find the API here. The descriptions of the methods are included in this file as comments.
    in reply to: Windows XP Compatibility #2193
    1. No. Don’t use the previous versions of Rapid SCADA. Install the actual.
    2. Yes, you can.
    Note: Rapid SCADA doesn’t officially support Windows XP and it is not tested on XP, but it should work most likely. The web app have to be installed manually.
    in reply to: Communication errors #2192
    Unfortunately, the link to the image you provided doesn’t work. Can you post the correct link?
    in reply to: Communication errors #2179
    The device sends not enough bytes: Receive (4/5). 5 bytes expected in the second part of package according to Modbus standard.
    You can analyze packages using http://modbus.rapidscada.net/
    If ModbusPoll can show communication protocol, let’s compare with Communicator.
    in reply to: Button object #2177
    Set the properties:
    Action = Send command
    Output channel = output channel number that you already created in Administrator to turn on/off a relay.
    in reply to: Get wrong values from registers #2176
    Please provide the additional info:
    1. Screenshot of Modbus template
    2. Screenshot of the values that you receive (Device Data tab in Communicator).
    3. What values you expect?
    Probably, you should try different order of bytes (in Modbus template) to decode floats. For example, 2301
    in reply to: Computer code #2175
    Computer code is shown by commercial plugins. First of all, you need to install the plugin. If you do not use commercial plugins, you don’t need any key.
    in reply to: webstation Scheme loading failed. Try to reload scheme #2170
    This is a known bug. It relates to the web server XSP4 that is used on Raspberry.
    Fortunately, there is a workaround. The idea – creating 2 instances of Webstation to local and remote access.
    How to:
    1. Copy the files from /opt/scada/ScadaWeb/ to /opt/scada/ScadaWebRemote/
    2. Grant access to the copied files.
    3. Register the web application:
    sudo mono-xsp4-admin add –path=/opt/scada/ScadaWebRemote –app=scadaremote
    4. In case of using SD card, protect it by moving the created folder to RAM.
    5. Open http://Host name or IP address:8084/scadaremote
    in reply to: webstation Scheme loading failed. Try to reload scheme #2168
    Try the following:
    1. Restart Raspberry Pi
    2. Do not open Webstation locally after restart, but open Webstation from the Internet.
    Does it work?
    in reply to: Web Services #2164
    Also you can deploy 2 instances of Rapid SCADA: on the remote and on the office server, and connect them using the new Rapid Gate module.
    in reply to: Web Services #2163
    Hi Mat,
    If you prefer to keep the existing app unchanged, you need to create a module which will pass data from your custom server app to Rapid SCADA. You should use ScadaData.dll written in C# to integrate. See http://rapidscada.org/integration-with-rapid-scada/ “Second Way. Interaction Over TCP”
    The other approach is replacing the remote app to Communicator and export data from Rapid SCADA to 3rd party systems.
    in reply to: Event for alarm limits #2161
    You should run the Administrator app, open the Input channels table, choose the appropriate row of an input channel and set the following fields:
    – Tick Write Events checkbox
    – Define Lower alarm limit, Lower limit, Upper limit and Upper alarm limit cells
