Forum Home › Forums › Runtime Bugs › Webstation Bugs › Application error on new web beta app
- This topic has 5 replies, 2 voices, and was last updated 10 years, 1 month ago by
September 1, 2016 at 5:40 pm #1570
medvdev
ParticipantDear Mikhail,
I hav installed the new web app, it was working fine, but all of a sudden while i was trying to log in error message pop up:-
Application Error
Details:
Value cannot be null.
Parameter name: virtualPathWhat to look for?
thanx
September 1, 2016 at 7:33 pm #1572
How can I reproduce this error?
Could you send the error details from ScadaWebBeta\log\ScadaWeb.log ?September 2, 2016 at 2:59 am #1574medvdev
it is fixd..
thanks for promp reply..
September 4, 2016 at 4:19 am #1578medvdev
ParticipantThe error comes only when I try to change the config of webbeta in web configurator, I changed the break between diagram points from 90 to 20 then, after saving and restarting server, this error occurred on login page, for old web app no such issue is observed that is working fine as desired.
Application Error
Details:
Parameter name: virtualPathLogs of scada web
Before Change:-
2016-09-04 09:25:09 <*****-PC><DefaultAppPool><ACT> User information has been added. IP address: 172.168.0.225. Session: web0obyze3321ihitnicnif4
2016-09-04 09:25:14 <*****-PC><DefaultAppPool><ACT> Login: engineer (Dispatcher). IP address: 172.168.0.225
2016-09-04 09:25:14 <*****-PC><DefaultAppPool><ACT> User information has been updated. IP address: 172.168.0.225. Session: web0obyze3321ihitnicnif4
2016-09-04 09:25:21 <*****-PC><DefaultAppPool><ACT> Logout: engineer. IP address: 172.168.0.225
2016-09-04 09:26:11 <*****-PC><DefaultAppPool><ACT> Request SCADA-Server state
2016-09-04 09:26:11 <*****-PC><DefaultAppPool><ACT> Disconnect from SCADA-Server
2016-09-04 09:26:11 <*****-PC><DefaultAppPool><ACT> Connect to SCADA-Server “localhost”
2016-09-04 09:26:12 <*****-PC><DefaultAppPool><ACT> User information has been added. IP address: 172.168.0.225. Session: isbw0lavpysvdytsykma4qi3After change:-
2016-09-04 09:28:54 <*****-PC><DefaultAppPool><ACT> Request SCADA-Server state
2016-09-04 09:28:54 <*****-PC><DefaultAppPool><ACT> Disconnect from SCADA-Server
2016-09-04 09:28:54 <*****-PC><DefaultAppPool><ACT> Connect to SCADA-Server “localhost”
2016-09-04 09:28:56 <*****-PC><DefaultAppPool><ACT> Login: engineer (Dispatcher). IP address: 172.168.0.225
2016-09-04 09:28:56 <*****-PC><DefaultAppPool><ACT> User information has been updated. IP address: 172.168.0.225. Session: web0obyze3321ihitnicnif4
2016-09-04 09:28:56 <*****-PC><DefaultAppPool><EXC> Application error:
System.ArgumentNullException: Value cannot be null.
at System.Web.VirtualPath.Create(String virtualPath, VirtualPathOptions options)
at Scada.Web.Shell.ScriptPaths.GenerateHtml()
at ASP.mastermain_master.__Render__control2(HtmlTextWriter __w, Control parameterContainer)
at System.Web.UI.Control.RenderChildrenInternal(HtmlTextWriter writer, ICollection children)
at System.Web.UI.HtmlControls.HtmlHead.RenderChildren(HtmlTextWriter writer)
at System.Web.UI.HtmlControls.HtmlContainerControl.Render(HtmlTextWriter writer)
at System.Web.UI.Control.RenderControlInternal(HtmlTextWriter writer, ControlAdapter adapter)
at System.Web.UI.Page.Render(HtmlTextWriter writer)
at System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint)
Page: http://172.168.0.225/Rapid Scada/View.aspx
User: engineerSeptember 5, 2016 at 7:01 am #1582
MikhailModeratorThank you. I think, I’ve found the cause. But it is strange that this error occurs. Does it occur every time when you try to open a view or only once?
September 5, 2016 at 7:02 am #1583
MikhailModeratorDo not use Configurator for the new web app, it breaks the config. Override the ScadaWebBeta\config folder from the distributive. Edit config manually using any text editor.
