then I couldn’t save this change as kpModbus.dll
Please explain what do mean? How do you do this?
I think, it’s possible to solve your issue without changing KpModbus.dll. I can tell how to configure it if you provide more information: what value should be sent by an operator and what data (in hex format) should be sent to the device?
Update: usually the command 0x10 (Write Multiple Registers) is used for sending float data to a device. In this case you can tick the Multiple command checkbox in Communicator and send any data.
This reply was modified 9 years, 4 months ago by
MikhailModeratorWhich development environment You use? It is .NET?
I use Microsoft Visual Studio 2015 Community Edition.
In case of questions about programming, create new posts in http://forum.rapidscada.org/?forum=development-and-integrationLet me know when Bosch answers about Modbus TCP 🙂
MikhailModeratorYou can purchase a training and we will solve the issues together via remote connection. Please send an email to get information about the prices.
MikhailModeratorYes, you can do it using JavaScript:
scada.clientAPI.getCurCnlDataExt(cnlFilter, function (success, cnlDataExtArr) { if (success) { // your code here } });Please ask more specific questions.
If you’d like, we can create a simple application together as a part of training.
I’ve read. Definitely, there is no notes that Modbus is not standard. Strange, Bosch is well known brand.Before decide, you should try to read other kind of data – input registers and check if it works or not, and what the issues are.
Also I strongly recommend trying Modbus RTU mode. It is strict and includes check sum. There is no way to dodge with protocol.
The chart drawn by the web application of Rapid SCADA can’t be used for automatic mail, because it’s generated by JavaScript in a user’s browser. The special module have to be developed that run on a server side. We can develop the module for you as a custom development or consult you how to do it by yourself.
MikhailModeratorExample:
Expected value of the tag #1 is 10, actual value is 0.
MikhailModeratorCurrently, it’s not implemented. Planned in the future version of schemes.
MikhailModeratorI mean:
What is Enron Modbus?
Enron Modbus is a modification to the standard Modicon modbus communication protocol developed by Enron Corporation.
See http://www.simplymodbus.ca/FAQ.htm#enronmod
MikhailModeratorHi Marek,
Probably the device uses a derivative protocol based on Modbus, but not standard Modbus. And this is the cause of the problems. Please read carefully the device manual. What is written in the manual about the supported protocol?
MikhailModeratorDo you mean that you can open the web application locally, but can’t access remotely?
HTTPS may require additional setup. Does HTTP work?
MikhailModeratorTry requesting 8 coils.
It’s difficult to understand what values are expected in Communicator?
MikhailModeratorThe official Modbus specifications are here http://modbus.org/specs.php
You need http://modbus.org/docs/Modbus_Application_Protocol_V1_1b3.pdf and http://modbus.org/docs/Modbus_Messaging_Implementation_Guide_V1_0b.pdf
According to the Modbus specification, in the response
00 00 00 00 00 06 02 01 02 88 02
06 is “Number of following bytes”. You can see only 5 bytes after 06. So the response is not correct.The correct response would be 00 00 00 00 00 05 02 01 02 88 02
I think, Simply Modbus doesn’t validate the incoming data.
Do you have any idea why the device sends incorrect Modbus packages? -
