Please provide a screenshot with the settings of the module. I can’t find it in your files.What I intend to do is to insert 100 values based on a time schedule trigger for one input channel.How do I do that?
Could you clarify the task?
MikhailModeratorThe visible difference between en-GB and en-US is the date pattern. English is Day-Month-Year. US is Month-Day-Year. Does it change?
How you want to format values?
I answered here http://forum.rapidscada.org/?topic=installation-automatic-control-module
You did the right steps, but the version of the module you installed is newer that SCADA-Server. You should update the SCADA-Server app and then install the module again.
I installed the Automatic Control Module to insert a few hundred set of values automatically.Is that possible?
Yes, it’s normal.
Could you create a new topic in the appropriate subforum http://forum.rapidscada.org/?forum=installation-issues and copy your question?
This is a known error, I’ll help you.
Have you copied BaseDAT\*.dat files and restarted Server?
Do you login as administrator?
MikhailModeratorDownload this link. Then publish the web app similar to manual Webstation installation: http://doc.rapidscada.net/content/en/installation-and-run/manual-installation.html
Create an input channel of calculated real type and define its formula: Val(1) + Val(2), where 1 and 2 are the source channelsNovember 16, 2017 at 10:23 am in reply to: The " E_FAIL IOPCItemMgt.AddItems " Error occurred using the OPC connection #2812
Try this advice. Does the console app work?
Thank you!
This Modbus parser is a web application only. It’s possible to install it on your Windows machine as web app.
MikhailModeratorDefinitely.
MikhailModeratorCreate your own simple module.
MikhailModeratorhow to justify right the value od dynamic text in scheme sir?
Find Horizontal alignment property. Please create new topics for new issues.
MikhailModeratorCan you let me know if it’s possible to help in the development in any way? Is there any branch that holds the current work on this subject?
Thank you very much for your helpfulness. Due to the changes affect the core of scheme engine, it’s difficult to involve new developer. Your help will be very useful in creation of new different components when schemes can support them.
