Sending a heartbeat signal
Forum Home › Forums › Understanding the Software › Formulas › Sending a heartbeat signal
  • #2785
    hybrid
    Hi there,
    I’ve got an command set up for a modbus device. I can manually execute the command successfully.
    It is a heartbeat signal that must change from 0 to 1 every second for communication to work.
    How can I automate the command to constantly execute ( write 0/1 to modbus register).
    I do not want to have to initiate the heartbeat signal if possible, but always have it running in the background.
    #2789
    You should create an input channel that changes every second, for example: DateTime.Now.Second % 2 and use Automatic Control Module with on change trigger to send a command.
    #2802
    hybrid
    Thanks for reply. So is there no option to do this without purchasing the control module ?
    #2805
    Create your own simple module.
