We should activate it by default.
MikhailModeratorCould you open the code you interested in by GitHub and copy link to a particular line of code? Of course, I will help to understand.
What happens if PC is off? Do you loose some switching?
MikhailModeratorDo you ask me about the web page path to specify in the command?
MikhailModeratorDo you have a project on GitHub?
Please check the log of the web application.
Do you know where to find it?
MikhailModeratorOK 🙂
MikhailModeratorGood job!
Creating new versions, I will try to simplify the object model and configuration.
Have you tested the driver on Linux?
What are the next steps in your development?
Would you share the driver with the community?
When it is ready, I can add a link to http://demo.rapidscada.net/plugins/Store/Store.aspx
Try ASCII text (8 chars) or Unicode text (4 chars) formats. Minimum version of KpOpc.dll is 5.0.1.0
MikhailModeratorI usually use 8GB cards.
May you need to clean the card and install all from the beginning?
Rapid SCADA itself is very small. To realize how much space are needed for Mono and Apache, you should check the appropriate docs.Is it possible to get plain image file of the working RPI SCADA?
I don’t plan to create such image because Mono and other packages are updated often by their teams.
What image of Raspbian do you use?
MikhailModeratorIf it targets to .NET Core or .NET Standard, it should not use DCOM.
MikhailModeratorThank you for the details.
Set “Sending all device data” to 0 to switch off this feature.
Also you can set “Period” to 0:00:20 in devices properties instead of a delay. In this case, devices will be polled more predictable, may be.
MikhailModeratorI’ve never met such thread issues before. To be honest, I have no advice. You should to dig deeper ))
What libraries do you use to work with OPC UA? Could you provide a link?
MikhailModeratorThe dashboard plugin works after installation and Registration for Chart Pro
If you place several charts to a widget of a dashboard, Chart Pro is needed to show them. As I remember, the error message is not clear if Chart Pro is not installed.
MikhailModeratorI saw is that if you put a time value lower than the total cycle of data adquisition for all devices, you get 2 records each time
Could you explain this case more detailed and provide screenshots of your settings?
MikhailModeratorFirst of all, it is needed to analyze your system, specify work cases and then decide if the software should be optimized for the system.
