Viewing 15 posts - 4,906 through 4,920 (of 6,391 total)
  • in reply to: Trying to communicate with Chinese 8IN8OUT device #3795
    Seems, you do everything right.
    Is there any controller manual with request-response examples?
    in reply to: Write config back to database #3786
    The plan for the future is that a user creates a project on any computer and then deploy (publish) the project on a working Rapid SCADA instance.
    Probably, you mean some kind of back import from runtime configuration to a project. This may be an extension for the Administrator app.
    We are going to create new generation of Administrator where configuration process will be more solid. And may be this problem will disappear.
    in reply to: Data input #3775
    When we complete this module, you can specify SQL request to retrieve data from a database which has any structure. We are going to support Oracle, MS SQL, PostgreSQL and MySQL. You don’t need files working with DB.
    in reply to: How to send value #3774
    You have to create an output channel and specify it in a scheme or a table view.
    What is a particular issue? You can’t display a form to input a value or you can’t store it into a variable?
    in reply to: Data input #3771
    In this year it’s planned to develop a module that will receive data from a 3rd party database as input. As for me, Excel is not a good data source because it is not stable.
    Agent is not included in the distributive package. You should install it separately. At least in this year, it will be a separate application.
    in reply to: MQTT driver publish comma decimal point #3764
    Hi Peter,
    I suggest to create an issue on GitHub https://github.com/bersim/OpenKPs/tree/master/KpMQTT
    If you do this, the author of this driver receives a notification
    If you need, the dlls are here
    in reply to: how to send a modbus value #3760
    does rapid scada have a text box where i can set a value and then send it to the Modbus Device
    Yes. You need:
    1. Create an output channel.
    2. Specify this channel in a scheme or a table view.
    3. Configure a command in your Modbus template.
    Also read this article.
    In case of follow up questions, ask here.
    in reply to: inject a gauges or chart to the view #3759
    Probably, you should create a plugin that provide a gauge as a control to insert into a scheme. The example is PlgSchBasicComp
    Could you translate the error message?
    I suppose, the log says that we can’t connect to a device. Is it possible that the device doesn’t support several connections in parallel? Are you sure that the port 530 is correct? Usually 502 is used.
    For testing, you can try Hercules utility to connect. What is the result of this test?
    The forum does not allow to upload images, just links to them.
    in reply to: Driver gallery #3751
    I’ll push some drivers in the future.
    Would be great.
    This list integrated in each Webstation app is prototype of a gallery. When there are more modules, we can create filters and other features. May be add such web page on our website.
    in reply to: Roadmap #3749
    in reply to: Driver gallery #3748
    I was thinking about it too.
    What do you mean talking about a gallery?
    I just created scada-community repository. I hope, it will be used for the purpose you talk about.
    “scada” repository is for core applications and modules.
    in reply to: Nuget package reference #3747
    Probably it’s better. Maybe this will be changed in the future to nuget.
    in reply to: Using the new basic scheme components #3744
    Thank you too. You helped to find and fix the bug!
