Viewing 15 posts - 4,846 through 4,860 (of 6,391 total)
  • in reply to: Export to Database Module #3982
    You should create a new database connection in the module properties form and paste SQL requests for this connection.
    What is the particular question?
    in reply to: Events not being fired #3979
    This is a bit strange. On the other hand, I’m sure that the cause exists. Could you provide screenshots of the related input channels?
    in reply to: Minimal modbus system #3978
    Configuration of Rapid SCADA is prepared on Windows, then applied on Linux. I recommend watching the videos to learn how to configure Modbus.
    in reply to: HTTPS on Linux #3975
    I’ve opened an issue on Mono https://github.com/mono/mono/issues/9458
    Hope the Mono team will work on it.
    in reply to: Modbus TCP over GPRS (S27x GPRS RTU) #3974
    Hi Rodrigo,
    Usually a modem is TCP client while Communicator is TCP server. You should set the TCP server type of communication channel in Communicator and allow the incoming connection on Firewall. Setup a modem to connect to the IP or DNS name and TCP port of your server. You will see that a connection is established in a communication line log. If connection is OK, Communicator polls the devices.
    If something goes wrong, provide logs of the communication line.
    in reply to: Siemens Logo! Modbus #3972
    You may contact the Logo support, provide them communication log and ask for explanation about the device behaviour.
    in reply to: Elastic Report Flexibility #3970
    Could you send me an email to this address? I will estimate a cost of the update and answer by email.
    in reply to: Events not being fired #3969
    Try switching the event filter to “All Events”. May be they are not visible.
    Also look for the events in the GUI of SCADA-Server.
    We need to understand if there no events at all or they are hidden.
    Please write here about the result.
    in reply to: Siemens Logo! Modbus #3966
    According to the communication line log, the device understands your command. Nothing happens because of a device logic. You should check that you specify the correct address and value of the commands.
    Does the manufacturer provide an utility application that can send the required commands to compare data packages?
    in reply to: Responsive Web Design #3959
    I’m sure how do you expect them to work.
    in reply to: log storage location #3958
    Probably. You should test.
    in reply to: ModDBExport #3955
    In my opinion, this is not optimal. I think, the best way is export the configuration database to the external DB and, because of this, have a relation between channels and devices (and other information).
    To export the configuration database we should develop a module that would be integrated with Administrator.
    in reply to: log storage location #3953
    You can set the path of data archives in the SCADA-Server settings:
    SCADA/ScadaServer/Config/ScadaServerSvcConfig.xml
    in reply to: Responsive Web Design #3952
    Could you provide an example of a basemap?
    in reply to: log storage location #3944
    What logs do you need to save to the external disk?
