Viewing 15 posts - 4,606 through 4,620 (of 6,391 total)
  • in reply to: Change event sound #4645
    Sound Alarm Module doesn’t depend on browser. For example, a user close a browser however he can hear alarms. This may be useful for some cases.
    in reply to: Bit Toggle #4644
    I agree that Automatic Control Module is the easiest way to implement reset. If you need help during configuring the module, ask here.
    in reply to: Changing setpoint values for a Modbus Device #4643
    1. You need to create commands in the Modbus template.
    Test that the commands work well in Communicator.
    2. Create output channels using Administrator and configure user interface.
    In case of follow up questions, please provide screenshots of your settings and communication logs.
    in reply to: Change event sound #4637
    Is there any way to invert the color of “on/off” events?
    Read this.
    in reply to: Change event sound #4636
    Sound Alarm Module works on SCADA-Server and doen’t relate to the web application.
    Also you can replace the default sound file C:\SCADA\ScadaWeb\plugins\Table\sounds\event.mp3
    in reply to: Database Admin on Raspberry Pi #4631
    Please find how_to_use.txt in the Linux installation package.
    Also Agent is very useful.
    in reply to: ChartPro installation error #4627
    You need Webstation 5.0.6.1. See http://doc.rapidscada.net/content/en/version-history/ for the details.
    in reply to: Database Admin on Raspberry Pi #4626
    Putty and WicCSP utilities help you to work on Linux.
    Please ask particular questions to get relevant help.
    in reply to: Run Self ssl to secure scada #4625
    Thank you for the info.
    in reply to: localhost/scada/ #4624
    Thanks for saying that the issues are solved!
    in reply to: Run Self ssl to secure scada #4613
    Thanks for this question.
    Use this update special for HTTPS.
    in reply to: localhost/scada/ #4612
    IIS doesn’t work. No reason to reinstall Rapid SCADA.
    I can try to fix IIS issue using a remote connection. This is a commercial service.
    in reply to: OPC write value issue-IBH opc server #4608
    Can you give some template o examples to create a instance in KpOpclogic class?
    Could you clarify what example do you need?
    in reply to: localhost/scada/ #4607
    Am I understand you correcly: When you open this link http://localhost on your server, you get “This site cant be reached”?
    You should reinstall Rapid SCADA. This issue relates to IIS.
    What OS do you use?
    Try this advice.
    in reply to: ChartPro installation error #4606
    Please check version of the Webstation app and the version of Chart Pro. What are the both versions?
