MikhailModeratorI meant if you click a component in a list of available components. To cancel the selection, click a pointer.
MikhailModeratorMany users ask for this feature. I suppose, we will implement it, but I can’t say when.
You can deploy it on your server and perform penetration testing.
Click pointer if you need to deselect a component that is recently clicked.
You need to manually select the next day. Would you like the application automatically switch a day?February 8, 2019 at 1:56 pm in reply to: Elastic Report and Chart Export function through iPad #4977
Right now, the Elastic Report page is fully functional when viewed using iOS device.
I am very glad. What application is used by iPad to open PDF and Excel?
Do you have any idea how to address the issue of ‘Export’ option not appearing in the Chart window when viewed using iOS device?
Open C:\SCADA\ScadaWeb\plugins\ChartPro\js\chartproform.js
Find$("#hlExport").parent().addClass("hidden"); // hide Export menu itemand comment or remove it.
MikhailModeratorYou need an input channel that stores max. value of each day. Than use this channel in your report configuration file.
You need:
1. Add commands in your Modbus template.
2. Check that the commands work well in Communicator.
3. Create output channels in Administrator to send commands from Server and Webstation.
MikhailModeratorThe new formulas for moving (rolling) averaging are shared here. Thanks a lot to Horacio for sponsorship.
February 1, 2019 at 2:37 pm in reply to: Elastic Report and Chart Export function through iPad #4968
However, I am unable to click on the select-box for the formats ‘Excel’, ‘PDF’, ‘HTML’.
The old scripts may be cached. Can you clear browser cache on iPad?
January 31, 2019 at 2:58 pm in reply to: Elastic Report and Chart Export function through iPad #4964
MikhailModeratorreplace the first line of the fragment to
if (false && scada.utils.iOS())The features should be enabled on iPad. How do they work?
January 31, 2019 at 2:57 pm in reply to: Elastic Report and Chart Export function through iPad #4963
MikhailModeratorLet’s play with Elastic Report.
Open C:\SCADA\ScadaWeb\plugins\ElasticReport\js\elasticrep.js
Find the code:if (scada.utils.iOS()) { // disable Excel and PDF formats for iOS $("#rbHtmlFormat").prop("checked", true); $("#rbExcelFormat").prop("disabled", true); $("#divExcelFormat").addClass("disabled"); $("#rbPdfFormat").prop("disabled", true); $("#divPdfFormat").addClass("disabled"); } else { var format = localStorage.getItem(FORMAT_ITEM_NAME); // switch to stored format if (format == "PDF") { $("#rbPdfFormat").prop("checked", true); } else if (format == "HTML") { $("#rbHtmlFormat").prop("checked", true); } }January 31, 2019 at 2:55 pm in reply to: Elastic Report and Chart Export function through iPad #4962
Replace the newly bought iPads with Android tablets?
I would not like this way.
Minute Data report are functioning normally on the iPad.
This is interesting. My iPad can’t open Minute report. What application opens this report on your iPad?
Is it due to the licensing of Elastic Report and Chart Pro which limits the function on iPad?
Is there any way to enable these functions on the iPads?Only technical reason. The cause is that iPad has no internal location to save report files. May be this changed since the reports were developed. We should try to run them and see what happens.
MikhailModeratorCould you provide the info listed below?
1. Sequence of steps that reproduces the problem.
2. Expected result.
3. Actual result -
