Viewing 15 posts - 4,411 through 4,425 (of 6,391 total)
  • in reply to: Read .dat file file #5175
    Thanks for the detailed description.
    in Authentication option, i choose Windows Authentication, so i think Password of this field is my computer.
    Windows Authentication is when you specify no password. Select an option with a password.
    in reply to: Rapid Gate #5169
    Rapid Gate is needed for data exchange between many instances of Rapid SCADA. For example, big central instance and many small local instances. You need to install a Rapid Gate and get a license for each small local instance of Rapid SCADA.
    in reply to: Read .dat file file #5164
    As I know it’s possible to connect to Excel like it is a database. I didn’t try it. If you can do this, then you can read data by KpDbImport driver.
    in reply to: Programming #5153
    1. Define a function in the Formulas table.
    2. Use the function in the Formula field of a channel.
    in reply to: Address Modbus RTU #5152
    Provide log of the communication line when send a command.
    in reply to: To display exact Time And Date of Event occur #5151
    Switch channel type to Calculated Real and remove Signal.
    in reply to: PDF Reports #5145
    Try this update. Copy ScadaData.dll to C:\SCADA\ScadaWeb\bin
    Don’t forget to backup the existing DLL.
    Please write here about the result.
    in reply to: Programming #5144
    I don’t understand the question, sorry.
    in reply to: Address Modbus RTU #5143
    For testing purposes, send commands directly from Communicator.
    Write here what command you need to send (register address, number of registers, value).
    in reply to: Read .dat file file #5137
    in reply to: Read .dat file file #5136
    You should not write to DAT files directly. You should develop a driver for Communicator that reads Excel file. Example of the driver is here.
    1. When you read data from physical device, the beginning data has it been saved in .dat file or .sql file or both?
    SCADA-Server saves to DAT.
    2. Where does TableEditor take data to display in web? Because i want to change a huge data into TableEditor, i don’t know .dat file’s format to implement my project.
    Table editor creates table views in XML format. The web application takes data from SCADA-Server to display them. Ready to use classes that work with DAT are here.
    in reply to: PDF Reports #5135
    That’s interesting. I will check and write here about a result.
    in reply to: TCP/IP or MQTT #5134
    You can find MQTT driver for Rapid SCADA on this page. Instructions are available on the home page of the driver.
    in reply to: Programming #5133
    1) Why kindly how do I enter numeric data or text type in the rapid scada example textbox in other platforms? Read bar code too?
    If you need to send command to a device, you should create an output channel. See the default configuration, for example.
    2) Is there any script language to programming events or routines or other logic associated with the tags?
    1. You can use C# for writing formulas.
    2. Automatic Control Module allows to send commands on different conditions.
    in reply to: Cannot add new components in ScadaWeb #5124
