Viewing 15 posts - 421 through 435 (of 6,387 total)
  • in reply to: Automatic Control Module – Registration key invalid #17144
    Map plugin and ChartPro are still working and registration key is still valid even if I see computer code is different there too.
    They might stop after restart. Let’s check the new codes.
    in reply to: Automatic Control Module – Registration key invalid #17143
    Dear Marko,
    Please send a new computer code by email to check the differences.
    In Chart Pro settings you can create a profile without a legend.
    To set a custom title, it should be a predefined chart accessed by a link.
    in reply to: Custom status icons on map #17132
    Noted with thanks.
    in reply to: Migrating V5.84 projects to V6 #17131
    Valid link to the Utils folder.
    in reply to: Application is not ready error #17126
    According to the log file, the Webstation application cannot connect to the Server service.
    Please check ScadaServer.log for additional details. Are there connection attempts? Is Communicator connected to Server?
    in reply to: Desktop Runtime #17119
    If I understand the question correctly, you mean a desktop application that works as a SCADA client. If so, there is no such plans. May be we will make a desktop wrapper for the web interface in the future to make the interface more familiar to some users.
    in reply to: Logging fast I/O #17117
    The archive status “Not Ready” means that some errors occurred. Check for the error details in the log files.
    in reply to: the issue of http error 503 #17116
    Try it.
    in reply to: Logging fast I/O #17111
    Please provide screenshots of the settings and the error. Also check the archive status in ScadaServer.txt
    in reply to: Missing PlgMimic.xml file #17110
    Up to date version of new mimic diagrams was included in Rapid SCADA 6.4.3.
    When you create a new project, PlgMimic.xml is added by default. You can find this file in the project template SCADA\ScadaAdmin\Templates\EmptyProject.en-GB\Instances\Default\ScadaWeb\config
    in reply to: the issue of http error 503 #17104
    By default, IIS may stop if the web application not active. To prevent that, start Internet Information Services (IIS) Manager, select the ScadaAppPool application pool, open Advanced Settings of the application pool, and set the following options:
    General – Start Mode: AlwaysRunning
    Process Model – Idle Time-out: 0
    Recycling – Regular Time Interval: 0
    as described in this article.
    in reply to: New release Rapid SCADA 6.4.x #17102
    Rapid SCADA 6.4.3 has been released.
    – Upgrade new mimics
    – Downgrade Npgsql.dll due to compatibility issues.
    It makes sense to update from 6.4.2 to 6.4.3 if the above changes are needed.
    in reply to: Map Plugin question #17099
    More info here.
    in reply to: Map Plugin question #17098
    Thank you for the screenshot.
    I suppose, it’s needed to upgrade ScadaWeb to version 6.2.2.0.
    The currently used versions of the plugin and the web app use the different APIs.
