Viewing 15 posts - 4,261 through 4,275 (of 6,391 total)
  • in reply to: Modbus TCP Server #5574
    Rapid SCADA works as TCP client, not TCP server. It connects to a PLC which is TCP server and PLC keeps port 502 open.
    in reply to: Using Multiple VM Computers #5573
    1. Please clarify the question.
    2. Do you mean using real devices or simulators?
    There are 2 videos where shown how to simulate a Modbus RTU and OPC connected device.
    It would be better if you provide a diagram of your system.
    in reply to: Modbus RTU comunication issue #5567
    How the devices are physically connected to Rapid SCADA server?
    in reply to: Error exporting to dB #5563
    I’ve sent an email.
    in reply to: Error exporting to dB #5560
    after about 4 hours a first queue overflow alarm is coming out
    A long time needed for exceeding the queue size means that simple increasing the queue size doesn’t solve the issue.
    in reply to: Error exporting to dB #5559
    you should have my email where to write your offer for remote
    Please send email again to let me identify you correctly ))
    Your description is clear, but watching the process is more efficient.
    in reply to: Error exporting to dB #5557
    Likely the queue size is exceeded because of the error executing the request. What is the full situation in logs currently?
    I could connect to your machine remotely and research for the cause, but this service is out of free support.
    in reply to: Error exporting to dB #5553
    This is strange, because there is no column named “Infinity” in your SQL requests. Do you have any idea where you can mention “Infinity”?
    Also ExportEvents tag contains false that means that “Error export events” should not be printed in any case.
    May be another configuration is running?
    in reply to: Installation Rapid scada on a Raspberry Pi #5552
    That’s good!
    in reply to: Table view #5551
    Table views uses hourly data.
    If you’d like to watch minute data use Minute Data Report or Chart Pro Plugin.
    in reply to: Installation Rapid scada on a Raspberry Pi #5545
    Check Mono version by the command:
    mono --version
    You should get something like 5.20.1
    in reply to: Error exporting to dB #5544
    Please make screenshots of the settings of the export module where SQL requests are shown.
    in reply to: Unable to Extract Data #5543
    Use http://modbus.rapidscada.net/ for decode.
    And you get that the device returns the error:
    [02] ILLEGAL DATA ADDRESS
    You should check the register address using the service mentioned above.
    in reply to: Installation Rapid scada on a Raspberry Pi #5539
    Do you use Apache?
    You should check the installation steps related to installing the web server.
    Currently Mono .NET Framework is not integrated with the web server.
    in reply to: Hide Main menu for guest or custom users #5538
    You can remove the plugins page if you deactivate the Store plugin.
    If you need to remove whole menu, programming required.
