You can set it in the formula of output channel in Administrator.
For example, you can write a number there.
MikhailModeratorYou should check the dependencies. There are no magic.
MikhailModeratorLog, ScadaCommCommon and ScadaData are located in the same repository. Build them before. Don’t forget to switch from Debug to Release configuration when build.
MikhailModeratorThe possible cause is the settings of network equipment.
If Communicator works in the same LAN as SCADA-Server, I strongly suggest to specify Server IP address instead of DNS name. The important thing is that SCADA-Server opens TCP port 10000 for connection. It must be enabled on advanced settings of Windows firewall. In case you use DNS, it also must be allowed in the router settings.Have you checked the firewall and network equipment?
MikhailModeratorProbably, you got problems with NuGet references. Open NuGet manager and check.
KpSnmp and KpOpcUa uses NuGet packages.
The problems are in KpSnmp.dll. If you don’t need it, just unload KpSnmp project. If you need, check where it looks for SharpSnmpLib
In ElasticRepExample.xml there is a formula example:
<Cell calcType="Formula" value="=SUM(RC[-3]:RC[-2])" />The best way to get correct formula, is generating report without a formula, then open it in Excel, insert formula, save in the XML 2003 format and see what formula is in the file.
MikhailModeratorAfter you change Webstation settings, you have to download them into your project. Otherwise, you will override the settings by default when upload configuration.
Make sure that Elastic Report plugin is activated in Webstation at http://localhost/Scada/plugins/Config/Plugins.aspx
If it doesn’t help, provide more different screenshots.
MikhailModeratori taked to code source from github, but i will try with your link !
My link is also GitHub.
i try to use the ServerAdmin5, because the classic ServerAdmin
That’s correct.
i try to build ScadaAdmin5 i need the ScadaWebCommon5 Assembly but i only have the classic ScadaWebCommon
Current name is ScadaWebCommon. The issue is strange. Could you make a screenshot of Visual Studio solution explorer with expanded References node?
December 24, 2019 at 3:00 pm in reply to: Upload Configuration — Elastic Report Registration keys are not ignored #6255
MikhailModeratorAnyway, I suggest to add PlgElasticReport_Reg.xml into your project.
December 24, 2019 at 2:59 pm in reply to: Upload Configuration — Elastic Report Registration keys are not ignored #6254
If you uncheck “Ignore Registration keys”, it means that registration keys are not ignored and uploaded.
You should get the source code from the master branch v5.7.1
In this case, I hope, the projects will be consistent. And you get the same binaries that are included in the installation package.it say that WebUtils don’t have a method named QueryParamToIntArray
This method was deleted recently.
First, you should delete from the Rights table. Then from the Interface table.
When you delete from disk, there is no reference check.
MikhailModeratorThe message in the screenshot is not a error. You should check communication line log.
Where did you download KpMqtt.dll from? -
