The formula is incorrect.
It’s better to fix error in KpMqtt to make it stable. Could you write here the error which is written in communication line log when connection lost?
Like that
https://imgur.com/a/koJ8Stt
MikhailModeratorTo post screenshots, use https://imgur.com/
MikhailModeratorSince then some websites that I visit every day or at least every 2 weeks have buttons that run scripts but when I click on them now, nothing happens.
Rapid SCADA is not related to any other websites.
MikhailModeratorNow i am going to configure a rapid scada to send commands from buton in the scheme. Can it? How to configure it?
You should watch this video.
MikhailModeratorCould you send communication line log again? Resize the application window to show more information.
What converter do you use to connect the module to a computer?
MikhailModeratorI suggest to follow the videos. If something is not clear in the videos, please ask a particular question.
MikhailModeratorOn the screenshot you can see that Modbus RTU is used. But in the settings there is Modbus TCP. Seems that the screenshots were made in different time with different settings.
What Modbus type is needed, Modbus RTU or Modbus TCP? What is written in the device manual about that?
MikhailModeratorDoes PAC3200 use Modbus protocol?
Could you make screenshots related to the issue?
MikhailModeratorDear Han,
Please follow the suggestions written by manjey73. In case of issues, put links to screenshots here.
MikhailModeratorWhat projects have you successfully built before facing the error?
MikhailModeratorYou should download the source code using the link I mentioned in this thread.
MikhailModeratorIs there an easy tutorial to learn how to use Rapid SCADA?
Does Rapid SCADA have the ability to obtain decimal numbers from 64 bit double precision registers
Yes.
What version of Rapid SCADA and Administrator do you use?
I don’t understand error messages in Chinese. Could you translate?
Check this topic. It may help. -
