Viewing 15 posts - 3,766 through 3,780 (of 6,391 total)
  • in reply to: Error opening serial port #7110
    You should check this thread.
    May be this cause:
    I had exactly the same problem. I found that I had a windows printer setup to use the same port. As soon as I changed the port in the printers settings, the SerialPort.Open() worked.
    in reply to: language for the event parts #7109
    Oh, I’ve just realized that not all files were translated.
    in reply to: language for the event parts #7108
    It should be in C:\SCADA\ScadaWeb\plugins\Table\lang\ScadaTable.xx-XX.xml
    start from the line 117
    <Phrase key="lblAllEventsBtn">All Events</Phrase>
     <Phrase key="lblEventsByViewBtn">Events by View</Phrase>
    After changing, logout and login the web app.
    If you can fix it, please let me know. And I will add it to the language pack.
    in reply to: Realtime data get and set value #7105
    Do you need to develop a DLL that works as a SCADA-Server module?
    in reply to: Installation has completed with errors how? #7104
    Installation of Server application has completed with a error:
    Service ScadaServerService hasn’t been installed
    1. Open command line as administrator
    2. cd C:\SCADA\ScadaServer\
    3. run svc_install.bat
    What messages would you get?
    in reply to: language for the event parts #7101
    Chinese-Simplified translation was created by circler3. Thanks a lot to him.
    You could ask circler3 for updating the translation, or update it by yourself. Instructions are here.
    in reply to: Chart auto refresh every 2s and store date every 1s #7100
    You should update Rapid SCADA to v5.8.1 and update the plugins.
    in reply to: Realtime data get and set value #7096
    Please provide more info how your module should work.
    in reply to: Chart auto refresh every 2s and store date every 1s #7095
    > some data are missing
    Likely the device didn’t respond that periods of time.
    > would you please explain more on how to use the rolling mode, and how to put chart on scheme using extended scheme components
    In the rolling mode, a period of the specified length is displayed on chart. For example, 30 last minutes.
    Using Scheme Editor, put a chart component on a scheme and set its properties as you need. Select fixed or rolling mode.
    in reply to: AllenBradley PLC Polling Driver (Ethernet) #7089
    Cool!
    Should I add the driver to the repository?
    in reply to: read modbus register as ASCII #7088
    In the formula you should join the strings. Something like
    string s = "";
    for (int cnlNum = 101; cnlNum < 110; cnlNum++)
      s += ScadaUtils.DecodeAscii(Val(cnlNum));
    return double.Parse(s)
    in reply to: read modbus register as ASCII #7087
    do you have suggestion for that, any tested formular?
    You should develop a formula by yourself. The idea is the following:
    1. Create an input channel of the calculated type.
    2. Add a formula in the Formulas table
    double MyFunc()
    // your code here
    3. Use this formula for the created input channel.
    in reply to: Chart auto refresh every 2s and store date every 1s #7086
    In addition to the above, configure Chart Pro by editing PlgChartPro.xml, and set the RefreshRate parameter. I suggest use Chart Pro in the rolling mode if you need to refresh it often. To do this, use Dashboard Plugin, or put a chart on a scheme usgin Extended Scheme components.
    in reply to: write event trigger #7077
    It’s not supported.
    To do this, it can be a good idea to use Automatic Control Module which has to be upgraded for event generation.
    in reply to: Download configuration remotelly #7072
    May be we should change the size from 10485760 to 104857600 by default.
