May 20, 2021 at 1:00 pm in reply to: Which code of RF transmitter 315MHz can Rapid Scada send to RF Receiver? #8975
The screenshot looks pretty good. Thank you for the appreciation of our work.
Do you have any questions at the moment?
MikhailModeratorDo you mean that 2 relays are 2 different devices?
You need Automatic Control Module to send 2 commands by 1 click.
You send the 1st command as usual. A command trigger reacts on the 1st command and sends the 2nd command.
MikhailModeratorI guess that the Linux and mono is not very suitable for .net program
We will get rid of Mono and will move to .NET5 on Linux.
MikhailModeratorYou should try updating Rapid SCADA to the latest 5.8.3.
In Communicator 5.2.1.2 there was a fix may be related to the issue. See the history
The DataRefrRate parameter in the web app affects only the web interface. If you set it to 0, the default value is used.How do you interact between your application and Rapid SCADA?
MikhailModeratorWhen some lines are stopped, do other lines continue working?
Are there any error messages in log files?
What Communicator version do you use?
the communicator has been stop working without any information.
What OS do you use?
All lines stopped or only one line?May 14, 2021 at 1:05 pm in reply to: Which code of RF transmitter 315MHz can Rapid Scada send to RF Receiver? #8952
For the current moment I don’t understand how Rapid SCADA should behave according your task.
Nice 🙂
I’m curious, what if many event are coming into a moment? How does it sound?
May 13, 2021 at 12:59 pm in reply to: Which code of RF transmitter 315MHz can Rapid Scada send to RF Receiver? #8948
An I understand you correct:
When a button in Rapid SCADA is clicked, you need to send a static predefined sequence of bytes? And no response from device to Rapid SCADA?
MikhailModeratorGlad to read this 🙂
MikhailModeratorBoth A and B computer’s fire wall are off
Port 10000, 10001, 10002, 10010 are openedPlease check the connection using telnet or any other utility (e.g. Hercules).
Just try to connect via port 10000.
MikhailModeratorHello Steven,
Error Connecting to SCADA-server: No connection could be made because the target machine actively refused it 192.168.10.111:10000
This error is usually caused when firewall of the server machine blocks incoming connections to the port 10000.
I strongly suggest to move from classic OPC DA to modern OPC UA. It works much better in network environment.
May 12, 2021 at 2:04 pm in reply to: Which code of RF transmitter 315MHz can Rapid Scada send to RF Receiver? #8938
It’s better if you draw a diagram of the system, and show which communication protocols are used on different architecture levels.
