Viewing 15 posts - 2,911 through 2,925 (of 6,392 total)
  • in reply to: Displaying string instead of input #9587
    It’s possible. But the subject of this topic is not appropriate the question. Please create a new topic to discuss.
    in reply to: Influxdb Redis TdEngine export driver #9585
    The modules are added to the repository.
    in reply to: OPC UA Driver #9584
    in reply to: communicate device by 4G DTU #9583
    Does the DTU support TCP client mode? I mean, can it connect to the server by IP?
    in reply to: Displaying string instead of input #9575
    Despite the inconvenience, I suggest using enumerations. You could prepare the text in another text editor and then insert into the grid cell.
    In v6 it will be allowed to start each enumeration value from a new line with 1000 chars total limit. So, working with enumerations will be simplified in the future.
    in reply to: Displaying string instead of input #9571
    but only get the first 8 Numbers
    Input channels has 8 byte data size internally. That’s why string is truncated.
    If you have a set of predefined strings, you could use enumerations. The string values are entered in the Units table, and then the unit is specified for an input channel. Check Off-On unit for example. Input channel format should be set to enumeration.
    in reply to: I have this error in the web application #9570
    I have a error in acces to a webb app to the rapid scada,
    This subforum is about OPC connection. Please write your question in the appropriate section.
    in reply to: configure input channels through a web application #9563
    SCADA-Server initializes many internal data structures based on the input channels. After channels changed, at least mainLogic.Stop() and mainLogic.Start() should be performed as the manager does.
    in reply to: OPC UA Driver #9561
    Please try the update.
    Thank you for finding a bug.
    in reply to: OPC UA Driver #9558
    What is the driver version?
    Please provide screenshots of the settings and the error message, and communication line log.
    in reply to: couldn’t find basic and extra components in scheme editor #9557
    Try opening the PlgSchExtraComp.dll file properties and unblocking the dll.
    in reply to: Lost current data after reboot #9551
    The above answer is correct. In addition, I’d like to inform that in Rapid SCADA 6, current data can be flush on disk using the specified period to take care on a flash drive.
    in reply to: couldn’t find basic and extra components in scheme editor #9550
    If you installed the components, but the don’t appear, check the log file C:\SCADA\ScadaSchemeEditor\Log\ScadaSchemeEditor.log for the details.
    May be you need to unblock DLL files of the components.
    in reply to: Loggin server error #9544
    Open the services list in Windows and make sure that ScadaServerService is running.
    Also make a screenshot of the C:\SCADA\ScadaServer\Log\ folder
    in reply to: Can’t open server #9542
    The default configuration of Device 11 “ADAM-6015 Server room” works via Modbus TCP, not OPC server.
