Viewing 15 posts - 2,866 through 2,880 (of 6,392 total)
  • in reply to: Local Host Not Working (WEBSTATION NOT OPENING IN CHROME ) #9732
    Please provide the info as follows:
    1. What operating system is used?
    2. Is the root page http://localhost/ available?
    in reply to: Computer code generation #9731
    1. Open the Drivers page in Administrator.
    2. Select the KpModbusSlave.dll and click the Properties button, then click the Register Driver button.
    Also the code is written in a communication line log.
    in reply to: Datepicker of Events #9728
    When a new date begins, the expected behavior is that an operator should manually change the date picker. However, our customers often ask to change date automatically at midnight.
    So, automatic change of current date will be included (and already implemented) in Rapid SCADA 6. It affects table views. The event panel at the bottom has no date picker and shows the specified number of recent events. To get events for the selected date, a report should be generated.
    in reply to: Text formatting toolbar is missing (Forum, not SCADA) #9724
    Yes. Unfortunately it disappeared after the last forum update. I will check if it’s possible to get it back.
    in reply to: Modbus Comm Bug #9723
    6. Request element group β€œch1.012”
    7. Send (12): 05 43 00 00 00 06 01 03 04 4C 00 64
    8. Receive (0 / 7):
    9. Communication error!
    Item 8 waits for data during the timeout, expecting 7 bytes. No data was received.
    Network does not guarantee 100% packet delivery.
    in reply to: How to make Led blinking #9718
    In addition to the previous answer.
    Color also can be taken from channel status.
    Channel value 1 means that device is running.
    Custom channel statuses may change led color.
    So channel formula could be Cnl; (Second(DateTime.UtcNow) % 2) > 0 ? 101 : 102
    where 101 and 102 your custom statuses specified in the Event types table.
    And in the Scheme editor specify the Status color.
    • This reply was modified 4 years, 10 months ago by Mikhail.
    in reply to: Modbus Driver 5.1.3.1 of SCADA 5.8.4 #9716
    Copied from the history https://rapidscada.net/doc/content/latest/en/version-history/communicator-drivers-history.html
    KpModbus 5.1.3.1 (November 15, 2021)
    - Fixed data packet format for multiple commands
      Warning: no backward compatibility for multiple commands having elements of 4 bytes or more
    So it affects only multiple commands when you send more that 1 Modbus element.
    > For projects that are running on 5.8.2 and 5.8.3, should I update them to 5.8.4?
    In my opinion, if they work stable, you don’t need to update. New projects should be implemented on the latest Rapid SCADA.
    in reply to: Modbus Comm Bug #9715
    This mess of data can be caused by a too small timeout of the device polling. When old packet comes, the app is already sent the next request and waiting for the next reply.
    in reply to: Scheme Template and Dashboard #9713
    The title text is taken from the Title column the Interface table.
    OK πŸ™‚
    You can change it in the configuration of the web application.
    http://localhost/scada/plugins/Config/WebConfig.aspx
    After changing don’t forget to download the new settings into your project.
    in reply to: Scheme Template and Dashboard #9698
    In a template you can override the text of the title component and channel numbers. Other properties are fixed.
    in reply to: SchemeEditor #9693
    You can use scheme template to create many views (many records in the Interface table), and then use them as widgets in a dashboard.
    > we must create its base on basic components?
    You should check the source code of the basic component on GitHub https://github.com/RapidScada/scada/tree/master/ScadaWeb/ScadaScheme/PlgSchBasicComp
    Use the available source code as example.
    in reply to: Table editor – Configuration database not found #9690
    You should open Table Editor from Administrator by double click a table in the explorer tree. Then the editor can find the configuration database related to the opened table.
    in reply to: SchemeEditor #9689
    If you question is about Dashboard, you should create a new topic and specify a particular question.
