Viewing 15 posts - 2,836 through 2,850 (of 6,392 total)
  • in reply to: API to get line and device state #9815
    In Rapid SCADA 6 there is a feature to get a device state into a channel.
    But there is no similar feature to get line state. Will see, probably, device state is enough and line state is not really needed.
    in reply to: Connect two pc with RapidGate #9814
    Check Rapid Gate log file located in C:\SCADA\ScadaServer\Log for error details.
    in reply to: Basic Scada Functions #9811
    Improving schemes is in the plans.
    in reply to: Basic Scada Functions #9810
    Please check the Image Pack from https://rapidscada.org/download-all-files/
    You can put a Static or Dynamic Picture component on a scheme and use one of the above images. To prepare a scheme background it’s comfortable to use a 3rd party editor like Microsoft Visio, Libre Office Draw or Google Drawings, then export an image it to SVG and use in a scheme.
    To copy/paste a group of components, hold the Ctrl button and select components by a mouse.
    Also Scheme Templates can be useful if you have several equal schemes. The details about templates are here https://rapidscada.net/doc/content/latest/en/software-configuration/creating-views.html
    in reply to: TCP Api #9809
    KpHttpNotif sends the specified GET and POST requests. But it does not process responses. What is the case?
    Every device with the KpHttpNotif driver sends 1 request every session. It is specified by the device properties.
    in reply to: Tooltip on mobile browser #9808
    I confirm that this issue exists and should be fixed.
    Likely, bootstrap tooltips should be used to avoid adding additional library.
    Thank you for reporting.
    in reply to: ScadaWeb as Progressive Web Apps #9807
    This can be useful. Thanks a lot!
    in reply to: ChartPro Quuestion . #9806
    About the link
    1. Open a graph by yourself, setup it as needed, and copy the link
    2. Insert the address into the properties of the link component. By cut the beginning of the address, because a relative address is required. Try something like
    ../ChartPro/ChartPro.aspx?cnlNums=14&viewIDs=2
    in reply to: Connect two pc with RapidGate #9803
    The main PC:
    – Does not need Rapid Gate
    – Has static IP or DNS name
    – No controllers connected
    The “remote” PC:
    – Polls controllers
    – Needs Rapid Gate
    – Can have dynamic IP
    – Rapid Gate initiates connection to the main PC and uploads data automatically
    • This reply was modified 4 years, 10 months ago by Mikhail.
    in reply to: Plot in the future #9792
    Interesting task. Probably, you should use Grafana for this purpose.
    in reply to: ChartPro Quuestion . #9791
    You could create a table view with a limited number of channels to simplify selection. And hide this table view from the explorer tree.
    in reply to: ChartPro Quuestion . #9790
    > This list is to long , can I hide some of the channels from view ?
    Thank you for the screenshot. It’s impossible to hide channels in the current version. We will take this into account in the future.
    > On the same subject I then tried to add a link to a CharPro graph
    Where did you insert a link?
    in reply to: Connect two pc with RapidGate #9788
    Rapid Gate manual is here https://rapidscada.net/doc/content/latest/en/modules/mod-rapid-gate.html
    To get some answers, please ask a specific question.
    in reply to: TCP Api #9775
    in reply to: Plot in the future #9774
    Could you explain the entire task?
    Are the future data mixed with data received from the devices?
    May be you should integrate Rapid SCADA with Grafana to draw charts containing points in the future.
