Viewing 15 posts - 2,806 through 2,820 (of 6,392 total)
  • in reply to: ModDbExport Questions #9914
    @dateTime should be in the SQL request. Actually, there is @dataTime
    in reply to: Basic Scada Functions #9911
    You right, we are going to improve error messages.
    in reply to: background color of the chart #9910
    Schemes use Chart Pro inside a frame.
    > But the font is really blurry
    What monitor resolution and scaling do you use?
    What browser?
    Text is rendered by JavaScript on canvas, may be some parameter can affect it.
    in reply to: multi language support on webpage #9907
    Interesting idea. I will think about it.
    in reply to: After the custom unit is wrong, it cannot be modified #9906
    > The sign field is the unit displayed in the scheme, right?
    That’s right.
    in reply to: ModDbExport Questions #9903
    The module writes log files into C:\SCADA\ScadaServer\Log
    Please check if there are errors in logs.
    in reply to: Basic Scada Functions #9902
    Currently, you can also select components from a drop down list of the editor. If you provide friendly names to components, you can easily find them in the list.
    > Instead of “your not allowed to open this”
    Do you mean errors when a user opens a view?
    in reply to: background color of the chart #9900
    The chart component has the Background color property. But chart uses its own settings loaded from PlgChartPro.xml. You should find this file in your project and change properties in the XML file. You can create many XML files with different chart properties and use a particular file.
    in reply to: multi language support on webpage #9890
    Am I understand correctly that you are talking about displaying the same scheme (*.sch) in different languages?
    in reply to: After the custom unit is wrong, it cannot be modified #9889
    Please provide screenshots of the error and a sequence of steps to reproduce the error.
    May be you should refresh the Input channels table before using new units.
    in reply to: Basic Scada Functions #9888
    All files should be located inside the project: C:\SCADA\Projects\YOUR_PROJECT
    in reply to: Basic Scada Functions #9882
    You need 45 output channels. Which XML file do you mean? Probably, you don’t need any special XML file.
    > Would it be at all possible to add a new property for buttons and links?
    It’s a good idea which allows to use less channels. I’ve added it to the backlog.
    in reply to: multi language support on webpage #9881
    Webpage view shows an external page. How do you mean it should work?
    in reply to: To display exact Time And Date of Event occur #9880
    You are welcome.
    in reply to: To display exact Time And Date of Event occur #9875
    Good, thank you for the solution 🙂
