MikhailModeratorChart profile has a name and contains chart options. The list of profiles is defined in PlgChartPro_Config.xml
To define a group of trends, you can specify a chart view in the Views table. For example, https://ibb.co/m46125b
MikhailModeratorModem should be Siemens C35 compatible.
For example, we successfully used Huawei E1750
MikhailModeratorWhat parameter we need to change in the app pool options?
MikhailModeratorHi Louis,
According to my understanding, the possible architecture is as follows:
1. Each location is served by a separate Rapid SCADA instance.
2. We can have the central Rapid SCADA instance on the main server that collects primary data from locations. Or don’t have central SCADA, so the system can be decentralized.
3. There is a special module, named Rapid Gate, that transfers data between Rapid SCADA instances in the specified directions.
4. User management can be implemented either by the built-in Rapid SCADA features, or by using an external auth system.Please ask related questions to clarify the possibilities of a solution.
Note: what do you mean by “console”?
MikhailModeratorMay be you should try to find utilities that send AT commands to modem and test them.
MikhailModeratorDear Han,
Something wrong in SMS packet. To find a cause, it’s needed to learn SIM808 documentation and make a research. Such work is not included in support.
I recommend to use Telegram to send notifications. Or use special REST web services.
MikhailModeratorFor version 6 you need the appropriate version of components.
Extra Scheme Components 6 will be published with the next Rapid SCADA release.January 13, 2023 at 2:04 pm in reply to: After several days of running continuously, the rapidSCADA session is denied #11955
MikhailModeratorWhen the rapidSCADA session is terminated, the data cannot be updated
It tries to reconnect, but cannot.
Could modifying some RapidSCADA comm parameters help reduce the chances of it being rejected?
I suppose, disconnect is initiated by the OPC server. You should ask the OPC server developers why it closes connections.
MikhailModeratorif no one is using it (this is my guess, because it’s just my personal test) Webstation is stopped after 30 minutes
That’s true. This is how IIS works by default.
Open IIS management console, find application pool ScadaAppPool advanced options, and try to find a parameter to always run.
Let us know about the result, please.
MikhailModeratorThank you for sharing the experience.
JavaScript API version 6 is different from API v5.
SIM808 replies “ERROR” for message list request.
Did you try to send messages by commands?
Open file as administrator for editing.January 10, 2023 at 1:44 pm in reply to: After several days of running continuously, the rapidSCADA session is denied #11941
The issue happened the 1st time.
Do the OPC servers show active connections? How many connections in total?
What does Rapid SCADA 6 do if an OPC connection is closed by OPC server?
MikhailModeratorThe Arguments cell should be something like “../../custom/MyPage.html”
Path = “Test\test”
Title = “test” -
