詹森
Viewing 15 posts - 1 through 15 (of 55 total)
  • in reply to: can we implement pop-up messages on scadaWeb #17736
    詹森
    Hello, I see. Thank you
    in reply to: can we implement pop-up messages on scadaWeb #17733
    詹森
    Thank you. I’ll try it right away
    in reply to: GetChannelName #17702
    詹森
    Hello! Thank you very much for your answer. Wish you a wonderful day!
    in reply to: String read and write operations #17487
    詹森
    I see. It was my fault for not handling it well. There is a formula. Thank you. The problem has been solved
    in reply to: KpModbus – function code 16 (10 hex) Write multiple #17268
    詹森
    hello, Mikhail. How does the automatic control module implement the 0x10 function code using the modbus protocol and simultaneously write four register addresses?
    in reply to: Faster thread #16639
    詹森
    You mean that even with 5,000 computing channels, the most frequently used script would be something like this “GetBit(DataRel(-1), 0)”, but this should not have taken so long, right?
    I will try to analyze the cause of this issue later and then reply to you
    in reply to: Faster thread #16634
    詹森
    Hello, regarding the #16629 issue of manjey73, since I use a large number of channels, there are approximately 5,000 computing channels. This has led to a polling cycle of calculation taking up to 10 seconds. This is related to CPU performance. Is there any solution? Thank you very much for your help.
    Hello Mikhail, you mentioned that specific modules can be developed. Do you have any relevant materials or examples for this? Please help me when it’s convenient. Thank you very much for your assistance.
    in reply to: Faster thread #16628
    詹森
    Method 1: Call the script in the channel. It takes only 10 seconds to poll for one cycle (why is it so long because there are many computing channels).
    Method 2: Use EverySec (getDataFunc), but with one call cycle per second
    I’d like to ask if there are other ways to call a script (method, function) once every 100 milliseconds?
    Thank you for your help
    in reply to: Faster thread #16626
    詹森
    Due to the large number of data channels, I found that the script directly called in the channel has slowed down to about 10 seconds before calling the calculation once. If I want to call the calculation script once every 100 milliseconds, how can I achieve this? Could you please let me know? Thank you
    in reply to: Faster thread #16623
    詹森
    1. We have encountered a situation where there are many computations in the channel, resulting in the script being called in the channel only calculating once every few seconds. Therefore, this method is currently unavailable.
    2. Using “EverySec (getDataFunc)” can only calculate once per second at the fastest
    I currently have a requirement to perform a script calculation every 100 milliseconds to obtain the latest calculation results in real time. The main need is to meet some calculations that require rapid response. Could you please inform me if there are any other methods to meet such a requirement? Thank you very much for your reply. Thank you
    in reply to: Faster thread #16620
    詹森
    How can one implement their own timer? How to create a custom thread? Could you please explain the implementation steps or examples? Thank you very much for your help!!
    in reply to: Send Commond #16617
    詹森
    OK, thank you.
    in reply to: Send Commond #16615
    詹森
    The possible issue lies in the limitations of the self-control module. For instance, in an application scenario: you want to use a multi-channel trigger, but the multi-channel trigger cannot send data from the specified channel
    in reply to: Send Commond #16613
    詹森
    I’ll re-describe one of my scenes
    For example, if I want to determine that the conditions of Channel1==1 && Channel2==2 are met, and I want to send the Value of Channel3 through the self-control module (that is, Copy the value of Channel3), how should I do it? Thank you for your help
    in reply to: Send Commond #16602
    詹森
    Thank you for your help. Then I am even more looking forward to the optimization of the automatic control module. Just as I said above, after the multi-channel trigger is met, copy value can be performed using the specified channel, which will meet the vast majority of requirements
