KpModbus – function code 16 (10 hex) Write multiple
Forum Home › Forums › Communicating with Devices › Modbus › KpModbus – function code 16 (10 hex) Write multiple
  • #2107
    MarCus0
    Hi Mikhail
    There is a plan add other function codes to KpModbus.dll?
    Specially 16(10hex) which is frequently used in modbus devices.
    Will be nice even it will be available in comercial(paid) version
    For that I checked few trial version of OPC servers just for this funcjonality but no one works soo easy as KpModbus plugin.
    #2108
    Function 0x10 already supported. The driver KpModbus.dll uses 0x10 function if you tick Multiple checkbox for a command.
    #2109
    MarCus0
    Hi
    Thanks I will check.
    Thanks for a promptly answer.
    Marek
    #2110
    MarCus0
    KpModbus - command
    Hi
    See screenschot.
    Under dropbox is marked tick multiple.
    I good understand that for single coil(0x) will be 05(0x05), multiple will be 15(0x0F) and for (4x)holding register 06(0x06)-for single and 16(0x10)-for multiple write? I’m not at home just have some test instalation at front.
    Regards
    #2111
    Hi Marek,
    That’s right. You can check here.
    But the best way to check is watching communication log in Communicator.
    #17268
    詹森
    hello, Mikhail. How does the automatic control module implement the 0x10 function code using the modbus protocol and simultaneously write four register addresses?
    #17270
    Auto Control Module sends commands to Server. It is a universal logical module which is not protocol-dependent.
    To configure particular Modbus commands, edit the Modbus template in the device properties in Communicator.
