Hcinarli
ParticipantI’m not sure if I sent the correct log, but there are settings in the screenshots—you can check them.
Hcinarli
ParticipantHcinarli
ParticipantCan you please explain how I should test the xml files you sent, I dropped the files into the web config and wiew and uploaded them, but I don’t know how I should use them or whether I’m doing the right thing, can you explain step by step if possible?
Hcinarli
ParticipantI have already shared screenshots before, I have a sample project file in driveda so that you can check the operations I have done.
Screenshots :
https://ibb.co/Sr49STj
https://ibb.co/GczdZskThe result I get in the table view is only the current data “current” values as in the default settings, so no other values are registered.
This reply was modified 1 year, 10 months ago by
Hcinarli.
Hcinarli
ParticipantSorry I updated permissions you can now access google drive.
Hcinarli
ParticipantI will check for flexibility, so how should the channel properties be if I do it as a reminder, if possible, can you configure and send 1-2 channels in the project file I sent as an example?
Hcinarli
ParticipantI thought about designing a schema for daily data, but how will I get the data I want for the channels I want?
January 14, 00.00 Value
January 15, 00.00 Value
January 16, 00.00 valueDo you have an idea that will continue or renew itself periodically?
Hcinarli
ParticipantExcept for the table editor, where can I do this in rapid, in the logic of the table editor or can an improvement be made in the table editor, as in the hours related to the periodic keeping of daily and monthly data?
Hcinarli
ParticipantI left a link to Google drive, I would be happy if you can check and return, thanks
https://drive.google.com/file/d/1Oz7IkWQlKfkohyWVvvDU98ZYuDhcYCvY/view?usp=drivesdk
Hcinarli
ParticipantI have checked the UTC settings, I have also sent screenshots, and the sample project is also attached, and the table name I want to configure is “Günlük.tbl” I would appreciate it if you can check and return back.
Screenshots
https://ibb.co/GczdZskProject
Hcinarli
ParticipantIn the channels where I want to save the daily data, the daily data from the archive mask field is marked, the table settings are as in the picture I sent and I added the channels I want to see the daily data, the table view comes as 1 day ago and 00, but it does not save the data, I cannot see the fields of the next days in the table. Only the instant values of the chanels I added come.
Hcinarli.
Hcinarli
ParticipantI will need both in the future, but as an example for now
January 16, 00.00 valueI would be glad if it is possible to learn both in the form of periodically recording the instantaneous read value and displaying it in the daily data table and displaying the amount of the value read within 1 day in the column of the relevant day.
Hcinarli
ParticipantHello, were you able to check?
Exactly what I want to do is to save and list the data I read from the modbus protocol on a daily basis, I want to do the same operations for daily data as for hourly data in the table editor, I explained the operations I did in #15974 thanks.
Hcinarli
ParticipantHcinarli
ParticipantHi I thought it was solved, I created a special archive type for myself for 3 minutes and configured the table editor accordingly, it kept 3 minutes of data, but the same process for daily data failed to save data every 24 hours, I shared screenshots, what is the reason or what should I do?
