takslasher
  • in reply to: Utility Pack 6.0 Instructions #15497
    takslasher
    We just want to have daily backup in easily accessible format.
    So right now are testing all the options and looking how it is going to work.
    Option is getting reports by the operator is also considered.
    Regards.
    in reply to: Auto Report #15490
    takslasher
    Hi Mikhail,
    Can you please disregard and delete above message. Looks like the system was not updated in time, or it was about missing data for the previous day.
    The report in XML format has generated without issues.
    My understanding is to have it in XLSX format I need Elastic addon?
    Regards.
    in reply to: Utility Pack 6.0 Instructions #15488
    takslasher
    Hi Mikhail,
    Yes it worked fine.
    Had issues extracting data when the data itself is missing. If the PC was shutdown (The report would not generate), when the sensor is not connected just generate blank data.
    Another question the data is saved in UTC, will there be any changes in script to convert while generating data?
    Regards.
    in reply to: Auto Report #15482
    takslasher
    Hi Mikhail,
    As there is no video or detailed manual for Auto Report installation I have stuck on testing it on version 6. Checking trial version of Auto Report. I have skipped email part as I dont need it.
    Create a communication line, device, and output channel to send reports by email to the specified recipients. (Created the line, but how to create output channel?)
    https://ibb.co/C879Cp9
    https://ibb.co/zbd1Pjg
    https://ibb.co/z4fzxr9
    Create a device and an output channel to send and receive commands for generating reports. (Same version 6 does not have output channel in tables).
    Add a new user, which is used to connect the application to Server. (Added)
    Configure Automatic Control Module to send commands on a schedule. (Added)
    Regards.
    in reply to: Utility Pack 6.0 Instructions #15481
    takslasher
    Thank you,
    Did not know where to look for this bit number.
    Was looking in Server -> Archives.
    It would be good to add somewhere as help to look in Secondary tables.
    Thanks Mikhail.
    in reply to: Utility Pack 6.0 Instructions #15474
    takslasher
    What does mean bit 11 in the table?
    When I open Archive list I have [#],[Active],[Code],[Name],[kind],[module]
    On #2 have minute archive, tried number 2 but the result is the same.
    in reply to: Logging Data per second #14918
    takslasher
    Thank you for the thread, moved it down the list and it helped (Server-> Archive).
    In version 5 reports could be viewed and exported in CSV format! Is it not the option anymore in 6.2.1 version?
    When trying to open XML file it says XML file does not appear to have any style information.
    Regards.
