DHague
  • in reply to: Uploading Product Recipe files #14095
    DHague
    These files are a list of instructions that are read by the program controlling the machine with an operation and position for the operation to occur at. Once the controlling program has read the file it will behave accordingly.
    So if we continued my previous example: a user would upload a file with instructions on where to put a stud in a wall, the machine would place the stud and nail it into place at however many mm was specified.
    Here is an example of a recipe:
    Frame_Length,2007.0
    Frame_Height,2743.0
    Frame_Width,89.0
    Num_Of_Operations,10
    Xpositions[0],19
    Xpositions[1],59
    Xpositions[2],324
    Xpositions[3],364
    Xpositions[4],610
    Xpositions[5],1219
    Xpositions[6],1746
    Xpositions[7],1786
    Xpositions[8],1829
    Xpositions[9],1988
    Xpositions[10],0
    Operations[0],’NVB’
    Operations[1],’NBB’
    Operations[2],’NVB’
    Operations[3],’NVL’
    Operations[4],’NVL’
    Operations[5],’NVL’
    Operations[6],’NVL’
    Operations[7],’NVB’
    Operations[8],’NVB’
    Operations[9],’NVB’
    Operations[10],”
    StudSize[0],’2×4′
    StudSize[1],’2×4′
    StudSize[2],’2×4′
    StudSize[3],’2×4′
    StudSize[4],’2×4′
    StudSize[5],’2×4′
    StudSize[6],’2×4′
    StudSize[7],’2×4′
    StudSize[8],’2×4′
    StudSize[9],’2×4′
    StudSize[10],”
    K_Zpositions[0],0
    K_Zpositions[1],0
    K_Zpositions[2],0
    K_Zpositions[3],0
    K_Zpositions[4],0
    K_Zpositions[5],0
    K_Zpositions[6],0
    K_Zpositions[7],0
    K_Zpositions[8],0
    K_Zpositions[9],0
    K_Zpositions[10],0
    in reply to: Creating Relevant Animations #13675
    DHague
    I could, but would that not be somewhat a bit of the worst of both worlds? If the machine is paused during an animated GIF that part of the animation would loop, and since I would have several parts the performance would suffer. Are non-animated GIFs lighter on upload? Since I have 165 frames I have to deal with I think the performance issues stem from the uploaded scheme files being over 100mb.
    in reply to: Creating Relevant Animations #13660
    DHague
    An animated GIF solves the performance issue, but how do I sync that GIF to the current state of the machine? For example, if the operator pauses the operation how do I make the GIF stop and how do I resume it when the operator resumes operation?
    in reply to: Creating Relevant Animations #13649
    DHague
    Currently the animation is a video hosted on a NGINX server that I spun up and is embedded in a frame.
    in reply to: Creating Relevant Animations #13648
    DHague
    While an animated PNG in the dynamic picture may work, I’m not aware of any way to pass the required state information to it to make it meaningful.
    Link to screenshot:
    FlippingTableHomeScreen
    in reply to: Formulas to control more than one channel #13536
    DHague
    The counters will be done in software, right now I reset a counter by using a SetVal(CnlNum, 0) formula.
    in reply to: Using Formulas With Scripts #13519
    DHague
    Thanks for the info,
    I have been trying to figure out how to get the channel to stop counting at a maximum value, using limits to do this has proven to be non-functional even when tied to the channel. Currently I have the E. Low and the Low set to 0, the High and E. High set to 165, and the dead band set to 1. Is there a way to have my channel stop counting once it reaches 165 using limits or is that under a different function?
    in reply to: Using Formulas With Scripts #13505
    DHague
    • This reply was modified 3 years, 1 month ago by DHague.
    in reply to: Using Formulas With Scripts #13504
    DHague
    Is there a way to edit the script to make it update every half second instead of every second?
