KeanoC
Viewing 15 posts - 1 through 15 (of 22 total)
  • in reply to: Server is unavailable #14054
    KeanoC
    Still not working
    in reply to: Server is unavailable #14047
    KeanoC
    We are getting a incorrect user or password error after performing a clean install onto the pc of v6.2 with the http://localhost:10008/Login link.
    in reply to: Server is unavailable #14045
    KeanoC
    no it does not
    in reply to: Server is unavailable #14042
    KeanoC
    Invalid username or password
    2024-02-09 12:50:02 [B100][B100$][ACT] Receive the configuration database
    2024-02-09 12:50:04 [B100][B100$][ERR] Error checking server connection:
    2024-02-09 12:50:12 [B100][B100$][ACT] Receive the configuration database
    2024-02-09 12:50:14 [B100][B100$][ERR] Error checking server connection:
    2024-02-09 12:50:22 [B100][B100$][ACT] Receive the configuration database
    2024-02-09 12:50:24 [B100][B100$][ERR] Error checking server connection:
    2024-02-09 12:50:32 [B100][B100$][ACT] Receive the configuration database
    2024-02-09 12:50:34 [B100][B100$][ERR] Error checking server connection:
    2024-02-09 12:50:42 [B100][B100$][ACT] Receive the configuration database
    2024-02-09 12:50:44 [B100][B100$][ERR] Error checking server connection:
    2024-02-09 12:50:52 [B100][B100$][ACT] Receive the configuration database
    2024-02-09 12:50:54 [B100][B100$][ERR] Error checking server connection:
    2024-02-09 12:51:02 [B100][B100$][ACT] Receive the configuration database
    2024-02-09 12:51:04 [B100][B100$][ERR] Error checking server connection:
    2024-02-09 12:51:12 [B100][B100$][ACT] Receive the configuration database
    2024-02-09 12:51:14 [B100][B100$][ERR] Error checking server connection:
    2024-02-09 12:51:22 [B100][B100$][ACT] Receive the configuration database
    2024-02-09 12:51:24 [B100][B100$][ERR] Error checking server connection:
    2024-02-09 12:51:32 [B100][B100$][ACT] Receive the configuration database
    2024-02-09 12:51:34 [B100][B100$][ERR] Error checking server connection:
    2024-02-09 12:51:42 [B100][B100$][ACT] Receive the configuration database
    2024-02-09 12:51:45 [B100][B100$][ERR] Error checking server connection:
    2024-02-09 12:51:52 [B100][B100$][ACT] Receive the configuration database
    2024-02-09 12:51:55 [B100][B100$][ERR] Error checking server connection:
    2024-02-09 12:52:02 [B100][B100$][ACT] Receive the configuration database
    The logs from there im not sure why its showing password incorrect since I havent used a password anywhere yet and this was a clean install op rapid 6.2
    • This reply was modified 2 years, 8 months ago by Mikhail.
    in reply to: Server is unavailable #14028
    KeanoC
    Those last 4 or so lines are what comes up when I go onto the page but when I try login I get that server unavailable issue and all my details are correct
    Here
    in reply to: Server is unavailable #14027
    KeanoC
    2024-02-08 13:17:34 [B100][B100$][ACT] Listener is stopped
    2024-02-08 13:17:35 [B100][B100$][ACT] Logic processing is stopped
    2024-02-08 13:17:35 [B100][B100$][ACT] Server is stopped
    2024-02-08 13:17:38 [B100][B100$][ACT] Server 6.1.1.1 started
    2024-02-08 13:17:38 [B100][B100$][ACT] Storage FileStorage 6.1.0.0 loaded from file C:\Program Files\SCADA\ScadaServer\FileStorage.dll
    2024-02-08 13:17:38 [B100][B100$][ACT] Start logic processing
    2024-02-08 13:17:38 [B100][B100$][ACT] The configuration database has been read successfully
    2024-02-08 13:17:38 [B100][B100$][INF] Number of active channels for archiving: 0
    2024-02-08 13:17:38 [B100][B100$][INF] Number of active channels for sending commands: 0
    2024-02-08 13:17:38 [B100][B100$][ACT] Compile the source code of scripts and formulas
    2024-02-08 13:17:38 [B100][B100$][ACT] Added the following dependencies:
        C:\Program Files\dotnet\shared\Microsoft.NETCore.App\6.0.26\netstandard.dll
        C:\Program Files\dotnet\shared\Microsoft.NETCore.App\6.0.26\System.ComponentModel.Primitives.dll
        C:\Program Files\dotnet\shared\Microsoft.NETCore.App\6.0.26\System.Console.dll
        C:\Program Files\dotnet\shared\Microsoft.NETCore.App\6.0.26\System.Diagnostics.Process.dll
        C:\Program Files\dotnet\shared\Microsoft.NETCore.App\6.0.26\System.Linq.dll
        C:\Program Files\dotnet\shared\Microsoft.NETCore.App\6.0.26\System.Private.CoreLib.dll
        C:\Program Files\dotnet\shared\Microsoft.NETCore.App\6.0.26\System.Runtime.dll
        C:\Program Files\SCADA\ScadaServer\ScadaCommon.dll
        C:\Program Files\SCADA\ScadaServer\ScadaServerEngine.dll
    2024-02-08 13:17:39 [B100][B100$][ACT] The source code of scripts and formulas has been compiled successfully
    2024-02-08 13:17:39 [B100][B100$][ACT] Module ModArcBasic 6.1.0.0 loaded from file C:\Program Files\SCADA\ScadaServer\Mod\ModArcBasic.Logic.dll
    2024-02-08 13:17:39 [B100][B100$][ACT] Module ModArcPostgreSql 6.1.1.1 loaded from file C:\Program Files\SCADA\ScadaServer\Mod\ModArcPostgreSql.Logic.dll
    2024-02-08 13:17:39 [B100][B100$][ACT] Archive Cur initialized successfully
    2024-02-08 13:17:39 [B100][B100$][ACT] Archive Min initialized successfully
    2024-02-08 13:17:39 [B100][B100$][ACT] Archive Hour initialized successfully
    2024-02-08 13:17:39 [B100][B100$][ACT] Archive Events initialized successfully
    2024-02-08 13:17:39 [B100][B100$][ACT] Start listener on port 10000
    2024-02-08 13:17:39 [B100][B100$][INF] Archive in DAT format: C:\Program Files\SCADA\Archive
    2024-02-08 13:17:39 [B100][B100$][INF] Archive copy in DAT format: C:\Program Files\SCADA\ArchiveCopy
    2024-02-08 13:17:39 [B100][B100$][ACT] Delete outdated data from the Min archive older than 08/02/2023
    2024-02-08 13:17:39 [B100][B100$][ACT] Delete outdated data from the Hour archive older than 08/02/2023
    2024-02-08 13:17:39 [B100][B100$][ACT] Delete outdated data from the Events archive older than 08/02/2023
    2024-02-08 13:17:42 [B100][B100$][ACT] Session with ID -6570016109691102215 created
    2024-02-08 13:17:42 [B100][B100$][ACT] Client 127.0.0.1 connected
    2024-02-08 13:17:42 [B100][B100$][ACT] User ScadaComm is successfully authenticated
    This is what comes up when I restart the server.
    in reply to: Server is unavailable #14017
    KeanoC
    Error connecting to SCADA-Server: Unable to read data from the transport connection: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
    This is the error I find in the logs how do I fix this?
    in reply to: Server is unavailable #14012
    KeanoC
    Im experiencing a similar issue where when I try logging in to the websation it says server unavailable and the instance manager is showing that the status is not supported but I receantly migrated from 5.4.1 to v6
    in reply to: Data Exporting #13746
    KeanoC
    The 003 is from the mysql which im no longer using but the 002 has the correct string
    in reply to: Data Exporting #13729
    KeanoC
    in reply to: Data Exporting #13728
    KeanoC
    And yes my module is active
    in reply to: Data Exporting #13727
    KeanoC
    Here is a screenshot I took of what I assume your talking about. My export logs dont seem to be apearing
    in reply to: Data Exporting #13718
    KeanoC
    Here are my logs after making the connection but i dont seem to be getting any data automatically exporting to my db.
    2023-11-28 08:11:09 [B100][B100$][ACT] Server 6.1.1.1 started
    2023-11-28 08:11:09 [B100][B100$][ACT] Storage FileStorage 6.1.0.0 loaded from file C:\Program Files\SCADA\ScadaServer\FileStorage.dll
    2023-11-28 08:11:09 [B100][B100$][ACT] Start logic processing
    2023-11-28 08:11:09 [B100][B100$][ACT] The configuration database has been read successfully
    2023-11-28 08:11:09 [B100][B100$][INF] Number of active channels for archiving: 335
    2023-11-28 08:11:09 [B100][B100$][INF] Number of active channels for sending commands: 0
    2023-11-28 08:11:09 [B100][B100$][ACT] Compile the source code of scripts and formulas
    2023-11-28 08:11:09 [B100][B100$][ACT] Added the following dependencies:
    C:\Program Files\dotnet\shared\Microsoft.NETCore.App\6.0.25\netstandard.dll
    C:\Program Files\dotnet\shared\Microsoft.NETCore.App\6.0.25\System.ComponentModel.Primitives.dll
    C:\Program Files\dotnet\shared\Microsoft.NETCore.App\6.0.25\System.Console.dll
    C:\Program Files\dotnet\shared\Microsoft.NETCore.App\6.0.25\System.Diagnostics.Process.dll
    C:\Program Files\dotnet\shared\Microsoft.NETCore.App\6.0.25\System.Linq.dll
    C:\Program Files\dotnet\shared\Microsoft.NETCore.App\6.0.25\System.Private.CoreLib.dll
    C:\Program Files\dotnet\shared\Microsoft.NETCore.App\6.0.25\System.Runtime.dll
    2023-11-28 08:11:10 [B100][B100$][ACT] The source code of scripts and formulas has been compiled successfully
    2023-11-28 08:11:10 [B100][B100$][ACT] Module ModArcBasic 6.1.0.0 loaded from file C:\Program Files\SCADA\ScadaServer\Mod\ModArcBasic.Logic.dll
    2023-11-28 08:11:10 [B100][B100$][ACT] Module ModArcPostgreSql 6.1.1.1 loaded from file C:\Program Files\SCADA\ScadaServer\Mod\ModArcPostgreSql.Logic.dll
    2023-11-28 08:11:10 [B100][B100$][ACT] Module ModDbExport 6.0.0.1 loaded from file C:\Program Files\SCADA\ScadaServer\Mod\ModDbExport.Logic.dll
    2023-11-28 08:11:10 [B100][B100$][ACT] Archive Cur initialized successfully
    2023-11-28 08:11:10 [B100][B100$][ACT] Archive Min initialized successfully
    2023-11-28 08:11:10 [B100][B100$][ACT] Archive Hour initialized successfully
    2023-11-28 08:11:10 [B100][B100$][ACT] Archive Events initialized successfully
    2023-11-28 08:11:10 [B100][B100$][ACT] Start listener on port 10000
    2023-11-28 08:11:10 [B100][B100$][INF] Archive in DAT format: C:\Program Files\SCADA\Archive
    2023-11-28 08:11:10 [B100][B100$][INF] Archive copy in DAT format: C:\Program Files\SCADA\ArchiveCopy
    2023-11-28 08:11:10 [B100][B100$][ACT] Delete outdated data from the Min archive older than 28/11/2022
    2023-11-28 08:11:10 [B100][B100$][ACT] Delete outdated data from the Hour archive older than 28/11/2022
    2023-11-28 08:11:10 [B100][B100$][ACT] Delete outdated data from the Events archive older than 28/11/2022
    2023-11-28 08:11:54 [B100][B100$][ACT] Stop listener
    2023-11-28 08:11:54 [B100][B100$][ACT] Listener is stopped
    2023-11-28 08:11:54 [B100][B100$][ACT] Logic processing is stopped
    2023-11-28 08:11:54 [B100][B100$][ACT] Server is stopped
    2023-11-28 08:11:57 [B100][B100$][ACT] Server 6.1.1.1 started
    2023-11-28 08:11:57 [B100][B100$][ACT] Storage FileStorage 6.1.0.0 loaded from file C:\Program Files\SCADA\ScadaServer\FileStorage.dll
    2023-11-28 08:11:57 [B100][B100$][ACT] Start logic processing
    2023-11-28 08:11:57 [B100][B100$][ACT] The configuration database has been read successfully
    2023-11-28 08:11:57 [B100][B100$][INF] Number of active channels for archiving: 335
    2023-11-28 08:11:57 [B100][B100$][INF] Number of active channels for sending commands: 0
    2023-11-28 08:11:57 [B100][B100$][ACT] Compile the source code of scripts and formulas
    2023-11-28 08:11:57 [B100][B100$][ACT] Added the following dependencies:
    2023-11-28 08:11:58 [B100][B100$][ACT] The source code of scripts and formulas has been compiled successfully
    2023-11-28 08:11:58 [B100][B100$][ACT] Module ModArcBasic 6.1.0.0 loaded from file C:\Program Files\SCADA\ScadaServer\Mod\ModArcBasic.Logic.dll
    2023-11-28 08:11:58 [B100][B100$][ACT] Module ModArcPostgreSql 6.1.1.1 loaded from file C:\Program Files\SCADA\ScadaServer\Mod\ModArcPostgreSql.Logic.dll
    2023-11-28 08:11:58 [B100][B100$][ACT] Module ModDbExport 6.0.0.1 loaded from file C:\Program Files\SCADA\ScadaServer\Mod\ModDbExport.Logic.dll
    2023-11-28 08:11:58 [B100][B100$][ACT] Archive Cur initialized successfully
    2023-11-28 08:11:58 [B100][B100$][ACT] Archive Min initialized successfully
    2023-11-28 08:11:58 [B100][B100$][ACT] Archive Hour initialized successfully
    2023-11-28 08:11:58 [B100][B100$][ACT] Archive Events initialized successfully
    2023-11-28 08:11:58 [B100][B100$][ACT] Start listener on port 10000
    2023-11-28 08:11:58 [B100][B100$][INF] Archive in DAT format: C:\Program Files\SCADA\Archive
    2023-11-28 08:11:58 [B100][B100$][INF] Archive copy in DAT format: C:\Program Files\SCADA\ArchiveCopy
    2023-11-28 08:11:58 [B100][B100$][ACT] Delete outdated data from the Min archive older than 28/11/2022
    2023-11-28 08:11:58 [B100][B100$][ACT] Delete outdated data from the Hour archive older than 28/11/2022
    2023-11-28 08:11:58 [B100][B100$][ACT] Delete outdated data from the Events archive older than 28/11/2022
    2023-11-28 08:12:01 [B100][B100$][ACT] Session with ID -275528625156651192 created
    2023-11-28 08:12:01 [B100][B100$][ACT] Client 127.0.0.1 connected
    2023-11-28 08:12:01 [B100][B100$][ACT] User ScadaComm is successfully authenticated
    2023-11-28 08:12:03 [B100][B100$][ACT] Client 127.0.0.1 disconnected
    2023-11-28 08:12:04 [B100][B100$][ACT] Session with ID -2293832663858227796 created
    2023-11-28 08:12:04 [B100][B100$][ACT] Client 127.0.0.1 connected
    2023-11-28 08:12:04 [B100][B100$][ACT] User ScadaComm is successfully authenticated
    2023-11-28 08:13:53 [B100][B100$][ACT] Created event with ID 7306392348303855930 and channel 304
    2023-11-28 08:53:24 [B100][B100$][ACT] Created event with ID 7306402531278643967 and channel 304
    in reply to: Update from 5.8.3 to V6 #13714
    KeanoC
    I downloaded the converter but the read me is a bit unclear it say I must type in the command but it keeps coming up as a non recognised command
    in reply to: Data Exporting #13693
    KeanoC
    It is active right over here
    https://imgur.com/a/FpvCADF
    I think their might be something wrong with my connection am I supposed to do something on the postgre side of things to get the connection correct? Ive only made the database and the password and those kinda things and looked at the connection details ofc.
