scr910
ParticipantI created a new communication line and it worked, so I am now communicating via the Wi-Fi network. Thanks again for pointing me towards the log Mikhail!
scr910
ParticipantWhen I restart:
2023-06-28 13:05:46 Initialize communication line 1 “Modbus”
2023-06-28 13:05:46 Load device template from file KpModbus_FTEG70_Diagnostics.xml
2023-06-28 13:05:46 Start communication line 1 “Modbus”2023-06-28 13:05:47 Establish a TCP connection with 192.168.8.1:502
Error establishing TCP connection: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond 192.168.8.1:5022023-06-28 13:06:08 Unable to communicate with Device 1 “Velocio_PLC” because connection is not established
2023-06-28 13:06:08 Attempt to establish TCP connection can not be earlier than 5 seconds after the previous.
scr910
ParticipantHere it is:
2023-06-28 13:01:53 Unable to communicate with Device 1 “Velocio_PLC” because connection is not established
2023-06-28 13:01:53 Attempt to establish TCP connection can not be earlier than 5 seconds after the previous.
2023-06-28 13:01:54 Establish a TCP connection with 192.168.8.1:502
It says it is looking for the IP which I use for ethernet/direct Wi-Fi access point connection. This is interesting, I have not looked at this page before. Thank you!
scr910
ParticipantThis order worked – thank you! I swore I tried this order but I guess it was 3201 that I tried, oops! I really appreciate your quick response and look forward to using RapidScada.
