KevinVt
  • in reply to: MQTT how to filter topic? #12744
    KevinVt
    Hello Mikhail,
    Below 2 messages are got from MQTT Server, these topics are same, and type are different.
    Message1:
    Topic=【report/allpoints】 msg=【{“saleid”:”10100001″,”gateid”:”10100001001″,”type”:”report”,”time”:”2023-06-01 13:10:00″,”sequence”:”22″,”source”:”da”,”meter”:[{“id”:”1″,”status”:”1″,”name”:”VrtDev1″,”values”:{“Pf”:”0.287000″,”Uab”:”391.900024″,”Ubc”:”392.300018″,”Uca”:”391.799988″,”Ia”:”0.400000″,”Ib”:”0.000000″,”Ic”:”0.400000″,”P”:”0.000000″,”Q”:”-0.160000″,”S”:”0.160000″,”EPI”:”2257.599854″,”EPE”:”10.800000″,”EQL”:”93.199997″,”EPIJ”:”0.000000″,”EPIF”:”0.000000″,”EPIP”:”0.000000″,”EPIG”:”0.000000″,”MDMINUTE”:”0.000000″,”MDHOUR”:”0.000000″,”MDDAY”:”0.000000″,”MDMONTH”:”0.000000″,”MD”:”0.000000″,”UaTHD”:”2.210000″,”UbTHD”:”2.510000″,”UcTHD”:”2.780000″,”IaTHD”:”0.000000″,”IbTHD”:”0.000000″,”IcTHD”:”0.000000″,”VUB”:”0.220000″,”CUB”:”100.000000″,”Pa”:”0.000000″,”Pb”:”0.000000″,”Pc”:”0.040000″,”IL”:”0.000000″,”EQC”:”980.000000″}}]}】 qos level= 【AtMostOnce】
    Message2:
    Topic=【report/allpoints】 msg=【{“saleid”:”10100001″,”gateid”:”10100001001″,”type”:”heart_beat”,”operation”:”notify”,”time”:”2023-06-01 13:10:07″}】 qos Level=【AtMostOnce】
    I wrote below js code to filter the message,
    —————-js code ————————
    let data = JSON.parse(payload);
    if (data.type == “report”) {
    // set values
    setValue(0, new Date(data.time).getTime());
    setValue(1, data.sequence);
    setValue(2, data.meter[0].values.Pf);
    setValue(3, data.meter[0].values.Uab);
    setValue(4, data.meter[0].values.Ubc);
    setValue(5, data.meter[0].values.Uca);
    else
    log(“Ignore HearBeat Data…”);
    It can print the log “Ignore HearBeat Data…” when got message with type “heart_beat”, and at same time, all channels value were set to null.
    I hope to get the channel value when got message with type of “report” and keep channel value unchange when got meesage with type “heart_beat”.
    Hope you can understand what I said.
    Thanks a lot.
    in reply to: Modbus RTU Communication Error #12707
    KevinVt
    Dear Mikhail,
    I got the solution of this question, default value of Timeout and Delay in RTU device are 0, it’s OK when set Timeout to 1000 and Delay to 200.
    Thanks.
    in reply to: MQTT not reading messages #12661
    KevinVt
    Got it, Thanks a lot!
    in reply to: MQTT not reading messages #12647
    KevinVt
    Hello Mikhail
    Thanks a lot for your answers, another question, for some data can not convert to double, such as name, how to get their value ?
    in reply to: MQTT not reading messages #12633
    KevinVt
    Hello Mikhail,
    I had setup MQTT Client in v6, and I can get data from MQTT broker, but I confused 2 questions, could you please help to check?
    1, all the data I got is double, can I get data in other format? for example, the sequence number is int.
    Current Data
    | # | Code | Name | Value | Channel |
    | 1 | .saleid | MqttReport.saleid | 10,100,001.000 | |
    | 2 | .gateid | MqttReport.gateid | 10,100,001,001.000 | |
    | 3 | .time | MqttReport.time | — | |
    | 4 | .sequence | MqttReport.sequence | 100.000 | |
    2, when use setValue(1,data.time) in js file for MqttReport.time, had error: “Error : Input string was
    not in a correct format.”
    I had try different format of timestamp, all got errors. How can I get correct time value?
    Thanks a lot!
