feltduck
Viewing 7 posts - 16 through 22 (of 22 total)
  • in reply to: Export data to XML #12281
    feltduck
    I’m having an issue when I try to connect to a PostgreSQL remote server.
    Do i have to modify Config\ScadaInstanceConfig.xml with my configuration?
    in reply to: Export data to XML #12272
    feltduck
    I’m using PostgreSQL and I’m having the same problem. I don’t know how to configure the data that I want to store. As i said before, by default is storing all the channel numbers, timestamp, values and status. I would like to choose the channels, and create some new rows.
    in reply to: Export data to XML #12251
    feltduck
    Thank you. And my last question is how can I configure the data that I want to store?
    By default the SCADA is storing channel number, timesamp, value and status and I want to store the code and name too.
    in reply to: Export data to XML #12230
    feltduck
    Thanks, and is it possible do it with mysql?
    in reply to: Export data to XML #12226
    feltduck
    Ok, thank you. And how can I export the data to a db every 15 minutes?
    in reply to: Connection through VPN error #12201
    feltduck
    I just reinstalled the modbus server and the scada and it’s going well.
    Now the doubt that I have is, how can I export all the data to a XML?
    Thanks for the help.
    in reply to: Connection through VPN error #12195
    feltduck
    I’ll check if the RPi doesn’t deliver the request trough VPN.
    Now I have another problem. I’m trying to connect again on local and it doesn’t work.
    This is the log that I’m getting:
    2023-03-07 08:57:33 Establish a TCP connection with 192.168.1.103:502
    2023-03-07 08:57:33 Communication session with the Device 10 “Priueba 2”, type: KpModbus, address: 10, call number: 192.168.1.103
    Request element group
    Send (12): 00 A9 00 00 00 06 0A 03 00 00 00 0A
    Receive (0/7):
    Communication error!
    Send (12): 00 AA 00 00 00 06 0A 03 00 00 00 0A
    Receive (0/7):
    Send (12): 00 AB 00 00 00 06 0A 03 00 00 00 0A
    Receive (0/7):
    2023-03-07 08:57:37 Disconnect from 192.168.1.103
    2023-03-07 08:57:37 Establish a TCP connection with 192.168.1.103:502
    2023-03-07 08:57:37 Communication session with the Device 10 “Priueba 2”, type: KpModbus, address: 10, call number: 192.168.1.103
    Send (12): 00 AC 00 00 00 06 0A 03 00 00 00 0A
    Receive (0/7):
    Send (12): 00 AD 00 00 00 06 0A 03 00 00 00 0A
    Receive (0/7):
    Send (12): 00 AE 00 00 00 06 0A 03 00 00 00 0A
    Receive (0/7):
    2023-03-07 08:57:41 Disconnect from 192.168.1.103
    2023-03-07 08:57:41 Establish a TCP connection with 192.168.1.103:502
    2023-03-07 08:57:42 Communication session with the Device 10 “Priueba 2”, type: KpModbus, address: 10, call number: 192.168.1.103
    Send (12): 00 AF 00 00 00 06 0A 03 00 00 00 0A
    Receive (0/7):
    Send (12): 00 B0 00 00 00 06 0A 03 00 00 00 0A
    Receive (0/7):
    Send (12): 00 B1 00 00 00 06 0A 03 00 00 00 0A
    Receive (7/7): 00 AF 00 00 00 03 0A
    Incorrect MBAP Header data!
