May 13, 2016 at 1:56 pm in reply to: WCF Service Error (HttpWebRequest_WebException_RemoteServer) #1152
Savan Tripathi
ParticipantThank u so much mikhail, You are genious. now i am able to see the schema..
May 13, 2016 at 9:37 am in reply to: WCF Service Error (HttpWebRequest_WebException_RemoteServer) #1146Savan Tripathi
ParticipantI am using windows 2008 server
By putting your URL in browser there is blank page with the error ::::
Application error: The HttpsGetEnabled property of ServiceMetadataBehavior is set to true and the HttpsGetUrl property is a relative address, but there is no https base address. Either supply an https base address or set HttpsGetUrl to an absolute address.
Savan Tripathi
ParticipantOK This is helpful.
But my question is, for example i am receiving live data from my device and i want to show that data here in rapid scada web browser, i am receiving data in postgreSQL table, so how can i able to connect it to RAPID SCADA server??Savan Tripathi
ParticipantOk i got that but .DAT file is belong to which DATABASE??
Savan Tripathi
ParticipantOk Thanks Mikhail. But my question is currently where the data is being stored . I mean what is default built in database for Rapid SCADA. and where it is located??
September 3, 2015 at 9:55 am in reply to: Rapid Scada not running on Web Browser due to 404 not found error #396Savan Tripathi
ParticipantHello mikhail what is default username and password after opening Rapid Scada login page
September 1, 2015 at 10:24 am in reply to: Rapid Scada not running on Web Browser due to 404 not found error #381Savan Tripathi
ParticipantHello Mikhail What is the payble cost for remote connection.??
September 1, 2015 at 10:02 am in reply to: Rapid Scada not running on Web Browser due to 404 not found error #380Savan Tripathi
ParticipantNow the error is changed and my .NET version is 4.0
HTTP Error 404.17 – Not Found
The requested content appears to be script and will not be served by the static file handler.The request matched a wildcard mime map. The request is mapped to the static file handler. If there were different pre-conditions, the request will map to a different handler.
Detailed Error Information:
Module StaticFileModule
Notification ExecuteRequestHandler
Handler StaticFile
Error Code 0x80070032
Requested URL http://localhost:80/Scada/Login.aspx
Physical Path C:\SCADA\ScadaWeb\Login.aspx
Logon Method Anonymous
Logon User AnonymousSeptember 1, 2015 at 5:46 am in reply to: Rapid Scada not running on Web Browser due to 404 not found error #369Savan Tripathi
ParticipantOk I found that pdf file and try to make installation as per setup but still not be able to solve that. now error is showing me following::
HTTP Error 500.19 – Internal Server Error
The requested page cannot be accessed because the related configuration data for the page is invalid.Module IIS Web Core
Notification BeginRequest
Handler Not yet determined
Config Error The configuration section ‘system.serviceModel’ cannot be read because it is missing a section declaration
Config File \\?\C:\SCADA\ScadaWeb\web.config
Logon Method Not yet determined
Logon User Not yet determinedConfig Source
21:
22: <system.serviceModel>
23: <behaviors>September 1, 2015 at 5:04 am in reply to: Rapid Scada not running on Web Browser due to 404 not found error #367Savan Tripathi
ParticipantHello Mikhail i am not able to find manual_setup_en.pdf so please give me link of it so that i can download it
August 31, 2015 at 7:51 am in reply to: Rapid Scada not running on Web Browser due to 404 not found error #345Savan Tripathi
ParticipantYes sir i have checked as per you told C:\SCADA\ScadaWeb exist , but scada application is not there in default web site
August 31, 2015 at 7:24 am in reply to: Rapid Scada not running on Web Browser due to 404 not found error #341Savan Tripathi
ParticipantWhile writing http://localhost/scada it is displaying following things as detailed error
HTTP Error 404.0 – Not Found
The resource you are looking for has been removed, had its name changed, or is temporarily unavailable.Module : IIS Web Core
Notification : MapRequestHandler
Handler : StaticFile
Error Code : 0x80070002
Requested URL : http://localhost:80/scada
Physical Path : C:\inetpub\wwwroot\scada
Logon User AnonymousAugust 31, 2015 at 7:15 am in reply to: Rapid Scada not running on Web Browser due to 404 not found error #340Savan Tripathi
ParticipantYes, its working fine . IIS7 homepage is there while go to http://localhost
