victorlamParticipantActually I have successfully installed the plug in and heard with sound before. But I forgot to capture the screen shots. May I have further advice support on this?
victorlamParticipantMy request is to have the sound alert based on the value of the register
0 – No sound
1 – Continuous sound alert
2 – Continuous sound alert
3 – Continuous sound alert
victorlamParticipantHello,
Thanks for the reply. I follow the advice and show with Safe only. Kindly advise if you can provide the steps in more detail.
1. Is semicolon in unit Mystates that can include 4 states here
2. Where can I define the condition for 0, 1, 2 and 3 at the event?
3. Alarm settings empty refers no value for lower limits lower alarm limits higher limits higher alarm limits?Thanks for the support.
victorlamParticipantUpper limit, upper alarm limit, lower limit and lower alarm limit did not support zero (0) value here. Value of register 30001 is one, there is no notification to be triggered. I believe all limits value need to be greater than zero.
September 22, 2022 at 1:26 am in reply to: How to show current date and time on scheme or dashboard #10874
victorlamParticipanthello, I also tried to use the formula DateTime.Now.ToOADate() and put this formula at one of my input channel eg 101. After upload to configuration, I do not see the current time and displayed with blank value or — at the scheme diagram.
Can you share how this can be implemented? Or I have something that is missing for the setup and implementation.
Or you can share screenshot to help on here.Thanks a lot!
victorlamParticipantOr can upper limit and upper alarm value can support the value of 0 here?
I have further tested late evening here and observed as follows:-
Upper limit 10
Upper Alarm limit 50If the channel value is 12, then there is acknowledge request and sound with low continuous tone.
If the channel value is 60, then there is acknowledge request and sound with high continuous tone.Now my channel values will be 0, 1, 2, 3 (or in binary 00, 01, 10 and 11).
00 is fine and safe. value =0
01 is alarm and not safe. value =1
10 is another alarm (break) and not safe to use. value = 2
11 is critical alarm (leak and break). Value = 3How can I get the notification trigger if I get the value of 01 or numerical value of 1? I try to set upper limit as 1 and upper alarm limit as 1. But there is no alarm that can be trigger when the received value is 1. How can I achieve the alarm trigger if the value received is one (1)?
Or if I suggest to set up a formula, for example multiply by 10, then I add a new input channel number and set the upper limit as 9. Once there is trigger of value 10, then the alarm will be worked.Or I can set an expression eg =1 at the upper alarm limit. If this can be done, it will be a good solution to see that.
September 21, 2022 at 12:19 pm in reply to: How to show current date and time on scheme or dashboard #10864
victorlamParticipantI also would like to know how can this be implemented? Time shown is very important.
victorlamParticipantI have noticed that there is a bell icon next to admin at Webstation page.
May I know if I did not install the notification plugin properly? Or I need to install this plug in again. Please advise the further action on this.
victorlamParticipantHello, may be new on this platform. Can you advisee how is my panel of notification panel? I already installed with trial test key. And there is a bell nearby.
What is the problem that cannot have the alarm all the time for such register?
victorlamParticipantHello Mikhail,
Please find the shared screenshot for your review reference and support:-
https://drive.google.com/file/d/1fn0kbncf7Se2M4usgGBeUFwU0_6SqVij/view?usp=sharing
https://drive.google.com/file/d/1KUcSuSRbmjOejlRmSZJWCYs9eN62t_ys/view?usp=sharing
I believe I am a new user that might have incorrect event or inproper setting behind.
FYI, my request is very simple. I would like to make a request that when a register value eg 30001 or 40001 that this value become one (1), then the alarm will be triggered and Webstation will be heard of alarm via notification plugin. Once the register value 30001 or 40001 or others changed to zero, the alarm will be off and there is no alarm triggered for alert or no sound (or as normal state).I might have something not correct. Please advise your help accordingly.
victorlamParticipantHello, I have successfully used the notification plug in and browser have the alert sound when the register 30001 changed from 0 to 1 or 1 to 0 or other values which has been changed with the values. The alert sound only alerts for 1 second or 1.5 second just with short duration and then stop.
How can I have the alert sound keep alive until the register value was back to original state eg from 1 to 0? 1 is my alarm state (or not normal) and 0 is the normal state.
Can I implement this scenario?Thanks for your help on this.
victorlamParticipantAnd sometimes formula is Cnl;Cnl or Cnl; CnlStat. Is this okay as a formula.Sorry, it is confused.
victorlamParticipantMay I know “15” refers to what item being stated here?
