October 9, 2022 at 8:54 am in reply to: Notification plug in (trial key vs paid registration key) #11205
victorlamParticipantActually I have tested this scenario with the same result for more than 3 weeks.
victorlamParticipantServer is not available…
victorlamParticipantI tried your advice but after the upload of the configuration, Webstation is not functional as before. I believe there is something wrong for the formula or other values setting. Please help to advise how this can be solved.
victorlamParticipantHi Hennie,
Thanks for your support. I will try my best to follow and test on this.
victorlamParticipantHello,
If possible, kindly share any new setting for event types. Or just use the default event values. No idea how to define a new event. Looks the existing events should be adequate for the application or no clear picture for all the events listed.
Thanks for your reply. Actually I have implemented this function already by defining a new unit eg LEAK with status normal, leak and break. But I would like to know if the other users use the same way The values are 0, 1 and 2 and 3.
0 normal
1 leak
2 break
3 leak+breakI use this together with notification plu in. Sometimes the acknowledge with event change is not stable. Not alert with status change every time.
victorlamParticipantHello Hennie,
Can you kindly help to provide the information if you can support? I would like to learn from your side if possible.
Please find the event log as below diagram as identified:-
https://drive.google.com/file/d/1ip6zdKw7QuY54wKQhgxwkBMmTFQx2i5m/view?usp=sharing
Kindly advise any idea to solve my issues.
victorlamParticipantI have more information to provide for your investigation on my issue case.
When I check the event record, userid showed 11 and 0.
I found that userid =11 works but not userid=0.Please advise the details on userid. How can the user set the userid?
What is the userid in Webstation?
victorlamParticipantI would like to have the alert with acknowledge if the register 30001 or 40001 equals to 1 or 2.
victorlamParticipantI would like to have the alert with acknowledge if the register 30001 eg equals to 1 or 2 or other values here.
victorlamParticipantI guess that the notification plug in does not support the discrete input by.
Please find the project file for review as below:-
https://drive.google.com/file/d/1QUKg9sjP_IUykz3e4UaWfr2ZPXaceW-z/view?usp=sharing
Actually, if I set with limits, the notification alarm works fine without issue.
Except the limit, the notification cannot be initiated with the acknowledgement and continuous long beep alarm.
Please find the snapshot as below:-
https://drive.google.com/file/d/1Uwi3rwV6ZPADMdD0zueoYgJFQXaZFT7E/view?usp=sharing
victorlamParticipantPreviously I try to set the high limit eg 0.1 and it works but this might not be a reasonable way to design the logic here.
My request is:-
Register 30001 = 1 Alert with notification (with acknowledgement)
Register 30001 = 2 Alert with notification (with acknowledgement)30001 = 1 water leakage condition
30001 = 2 cable break condition
30001 = 3 leakage and cable break togetherPlease help to advise the proposal on this.
