gabeirinhas
Viewing 9 posts - 46 through 54 (of 54 total)
  • in reply to: ModDbExport Questions #9913
    gabeirinhas
    First I had a connection problem with the server since I had not declared the corresponding port.
    Now I am getting the following error.
    2022-01-14 12:30:00 Error export snapshot by the trigger “LT1”:
    System.Data.SqlClient.SqlException (0x80131904): You must declare the scalar variable “@dataTime”.
    what am I doing wrong ?
    in the sql table it is declared from the manual example and in the server too
    thanks
    in reply to: ModDbExport Questions #9893
    gabeirinhas
    I have tried with the manual settings
    it still doesn’t work for me
    what am I doing wrong?
    https://drive.google.com/drive/folders/1xFSLfS8JqqsIA3oCamwTHYP50gw0kLi8?usp=sharing
    in reply to: ModDbExport Questions #9892
    gabeirinhas
    Hello
    I am trying to dump the data to a local sql database on the server itself
    I am new to this and have not been able on my own
    The idea is to dump the date and the value in the tables.
    https://drive.google.com/drive/folders/1vimJlHYrG7V6oZbh6CXuUPO5F28dwFVN?usp=sharing
    in reply to: Send command #9836
    gabeirinhas
    thanks
    in reply to: Send command #9834
    gabeirinhas
    Good afternoon, is there any way to send a command from the telegram chat, to activate a signal?
    I am able to send notifications with a trigger but I wanted to know if it is possible to send commands in the opposite direction.
    in reply to: Sending On / Off Commands to Modbus Register #9768
    gabeirinhas
    I am trying to activate a bit through a button.
    I don’t know what I’m doing wrong in the configuration
    Can you help me please
    attached photos
    https://www.mediafire.com/file/mv9wahbevj4c9pt/modbus.rar/file
    in reply to: Local Host Not Working (WEBSTATION NOT OPENING IN CHROME ) #9734
    gabeirinhas
    Integrity Check
    Command types…OK
    Command values…OK
    Channel types…OK
    Communication lines…OK
    Output channels…OK
    Event types…OK
    Number formats…OK
    Formulas…OK
    Input channels…OK
    Interface…OK
    Devices…OK
    Device types…OK
    Objects…OK
    Quantities…OK
    Rights…OK
    Roles…OK
    Role inheritance…OK
    Units…OK
    Users…OK
    The configuration database is correct.
    Device 1 “Test device”
    DLL : KpModbus
    State : normal
    Comm. session : 03/12/2021 15:30:27
    Command : time is undefined
    Comm. sessions (total / errors) : 567 / 0
    Commands (total / errors) : 0 / 0
    Requests (total / errors) : 1220 / 0
    Current device tags data
    | Signal | Name | Value | Channel |
    | ******** HR NIVEL ********************* |
    | 1 | LT1 | 562 | 101 |
    No archive data
    No events
    2021-12-03 15:28:50 <MLG-++++++><SYSTEM><ACT> Command 0x07 (request command) is received from the client 127.0.0.1
    2021-12-03 15:28:51 <MLG-+++++++><SYSTEM><ACT> Writing snapshot in the current data table is completed
    2021-12-03 15:28:51 <MLG-++++++><SYSTEM><ACT> Writing snapshot in the current data copy table is completed
    2021-12-03 15:28:51 <MLG-JMGABEIRAS><SYSTEM><ACT> Command 0x07 (request command) is received from the client 127.0.0.1
    in reply to: Local Host Not Working (WEBSTATION NOT OPENING IN CHROME ) #9733
    gabeirinhas
    Good afternoon
    OS Windows 10 Pro 64-bit (x64)
    Service Unavailable
    HTTP Error 503. The service is unavailable.
    in reply to: Local Host Not Working (WEBSTATION NOT OPENING IN CHROME ) #9730
    gabeirinhas
    Hello
    when starting sw in the web browser
    show me the error code
    “HTTP Error 503. The service is unavailable.”
    Server status is normal
    Communication with the ports is correct
    I have installed manually
    the problem continues
    Can somebody help me
