gabeirinhas
ParticipantHello,
Thank you very much,
I’ll get on it,
I hope I get it, it would be great,
Thanks for your help
gabeirinhas
ParticipantHello,
I have incorporated the table of formulas,
They work correctly,
I get the average using these 2 formulas,
MovAvg(5); AvgStat()
TimeAvg(10, 5); AvgStat()
I have been playing with them in order to get the sum of 2 values at the change of an input channel,
What I am trying to do is for example that, during 1 hour I get on one input channel 100.0 and after another hour I get 200.0, on the same input channel,
I try that another input channel picks up the sum of these 100.0 + 200.0
In the first input channel (904) where I receive the values to be added,
I put the formulaMovAvg(2); AvgStat()
In the second input channel (905) in order to obtain the sum, I put the formula,
Val(904) *2
I do not obtain the expected result,
I hope you can help me with this, thank you
This reply was modified 4 years, 1 month ago by
gabeirinhas.
October 24, 2022 at 1:17 pm in reply to: Digital Counter and calculate elapsed time for a channel in certain state #11373gabeirinhas
ParticipantOk,
If I use the formula
function double CalcSwitch(int counterCnlNum)
if (Val() <= 0 && Cnl > 0 && Stat > 0)
SetVal(counterCnlNum, Val(counterCnlNum) + 1);
return Cnl;
}“error CS1519: The token ‘double’ is invalid in a class, struct, or interface member declaration.”
return Cnl;
}Line 516, column 32: error CS0019: Operator ‘>’ cannot be applied to operands of type ‘method group’ and ‘int’.
Thanks in advance, best regards
October 22, 2022 at 10:26 am in reply to: Notification plug in (trial key vs paid registration key) #11346gabeirinhas
ParticipantIts ok,
October 22, 2022 at 9:45 am in reply to: Digital Counter and calculate elapsed time for a channel in certain state #11337gabeirinhas
ParticipantHello,
I am trying to use this formula in the formula table,
To have a counter each time it changes state 1 – 0
I get an error on the server,
The only way to get the server to accept it is to delete certain conditions but it still doesn’t work,
if (Val() <= 0)
return Cnl;
}Some formula available to make a counter that counts each time a channel changes state from 1 – 0, instead of using counter type, which counts both states,
Thanks in advance
gabeirinhas
ParticipantHello,
I have the following query,
If a channel receives an actual value of 100.0 continuously and after some time the same channel receives a value of 200.0
Is there a way to sum these specific values?
i.e. 100.0 + 200.0?
Thank u
gabeirinhas
ParticipantHello,
I have made the history the way you have indicated,
I use the automatic module to send a command when I want to make the record,
It works correctly, but there is a blind spot,
When 2 equal events are generated one after the other, only the first event is logged, because the logging is based on event to change,
Is there any way to generate the event in the same way without event to change, taking advantage of the triggering of the command?
Thanks in advance.
gabeirinhas
ParticipantHello,
I want to sum two channels,
the values keep increasing,
Both are channels without signal,
Both are real calculated type, one of them is based on a value with signal.
Basically I want that when the value of one of them changes, the result will be added,
Could you help me, thank you
I attach pictures
https://drive.google.com/drive/folders/1pwEn-hpt_Kkn6qjn3vjl8ZaZu2CSoL5T?usp=sharing
October 18, 2022 at 9:08 am in reply to: Notification plug in (trial key vs paid registration key) #11307gabeirinhas
ParticipantHello,
would it be possible for the mute button to be activated by default, instead of having to activate it, thanks
October 17, 2022 at 3:12 pm in reply to: Notification plug in (trial key vs paid registration key) #11300gabeirinhas
ParticipantHello,
I have purchased the notification plugin
I generate a notification assigned to a channel that in state 1 generates an event status.
When this happens, it triggers a notification and a corresponding sound,
I would like the bell to stop ringing when the channel returns to state 0 and generates a different event status,
Would this be possible,
Thank you
gabeirinhas
ParticipantHello,
You were right,
It is working correctly,
Thank you very much
gabeirinhas
ParticipantI have added the ticks formula to the formula table and it works correctly,
When adding the formula Tp,
I get the following error,
https://drive.google.com/file/d/183biP4UGyLkpZVKE2CW8Y3r5WdSlOC2d/view?usp=sharing
I hope you can help me, thank you
gabeirinhas.
gabeirinhas
ParticipantHello,
Sorry for my ignorance,
I am trying to implement the formula Tp, in the formula table,
When copying the content that it indicates in the same one,
int[] TpNum = new int[1];
long[] TpST = new long[1];
bool[] TpFlag = new bool[1];
public double Tp(double TpIn, long TpPT)
long ET = 0L;
bool q = Val(CnlNum) > 0;
bool tp_in = TpIn > 0;int res = Array.IndexOf(TpNum, CnlNum);
if (res == -1)
res = TpNum.Length;
Array.Resize(ref TpNum, res+1);
Array.Resize(ref TpST, res+1);
Array.Resize(ref TpFlag, res+1);
TpNum[res] = CnlNum;
}if (!TpFlag[res])
if (tp_in)
TpFlag[res] = true;
TpST[res] = Ticks();
if (ET < TpPT) q = true;
else
if (q)
ET = Ticks() – TpST[res];
if (ET >= TpPT) q = false;
else
if(!tp_in)
TpFlag[res] = false;
ET = 0L;
return Convert.ToDouble(q);
}The server stops working correctly,
Could you tell me how I could implement such a formula correctly,
I attach images of the process I perform
https://drive.google.com/file/d/1KWlFcQ5Y1vhg3GTUoQfnEbxQPMyw6Ls_/view?usp=sharing
Thank you, best regards
gabeirinhas.
gabeirinhas
ParticipantHello,
I have already found the first formula I needed in the forum, basically the error was that it did not distinguish between 0 and null
CnlStat > 0 ? Cnl : Val(); CnlStat > 0 ? CnlStat : Stat()
gabeirinhas
ParticipantThe other formula I need is that when a discrete channel = 0
The value of a real channel is copied,
into another real channel,
That is if when the discrete channel (742) == 0
Copy, the value of the real channel (743)
In the real channel (1033), when this happens, an event is generated with the value of the copied channel,
What formula should I use in the real channel (1033) to perform this operation,
Thank you very much in advance
