Zeus
Viewing 15 posts - 121 through 135 (of 165 total)
  • in reply to: scheme editor #8944
    Zeus
    hi
    we change the code and make it able to speak text.
    https://ibb.co/z2xNp6H
    in reply to: event triger #8939
    Zeus
    hi
    thanks a lot. it works. it confused me for a long while.
    in reply to: event triger #8935
    Zeus
    @mikhail
    hi
    i am waiting online.
    in reply to: event triger #8934
    Zeus
    in reply to: event triger #8926
    Zeus
    hi
    I got a new problem.
    I created a new channel. its type is calculated real. I use formula below
    “GetBit(Val(1001),0);Cnl==0?115:116”
    I checked the option ‘onchange’.
    There are always two events.
    The first one is caused by value change and the second is caused by status change.
    How can I fix it. thanks alot.
    in reply to: event triger #8925
    Zeus
    hi
    I have solved it. thanks a lot.
    in reply to: scheme editor #8924
    Zeus
    in reply to: scheme editor #8923
    Zeus
    hi
    will the V6 version save current data per second? now I use modinfluxdb driver to save current data in influxdb. but it is not convenient. that will be great if the V6 version supports current data saved in cur.dat file per second. we can do more analysis work on it. now the v5 version only saves minute data and hour data.
    in reply to: scheme editor #8922
    Zeus
    hi
    this is an online form editor. you can try it out.
    https://ibb.co/6s4xLXP
    the link address is below.
    http://form.making.link/basic-version/#/zh-CN/
    in reply to: scheme editor #8921
    Zeus
    hi
    these drivers and modules are still in development. there are still many changes and bugs in testing.
    I have a new idea about the scheme editor. the web station does not have self-adapting in different screens on different DPI. do you have a plan to solve that? I used to use some form editors. they use the bootstrap layout. it has rows and columns. we can drag them in the web station that can fit any screens on different DPI.
    the height of components we can use calc(100vh-px) or another way.
    https://ibb.co/jVcL0Xk
    I used to use razor page mix vue.js in net core3.1. it is convenient to handle data and easy to develop.
    https://ibb.co/vHCYvBK
    https://ibb.co/pvGV7sj
    in reply to: event triger #8920
    Zeus
    hi
    I have opened the archive files in Administrator and checked events not presented.
    https://ibb.co/17z4vgx
    https://ibb.co/nQ197rR
    https://ibb.co/QKJDtTz
    in reply to: scheme editor #8903
    Zeus
    hi,
    I really love this project.
    I have developed driver IEC104 and IEC61850.
    I have developed mod Influxdb and Redis.
    I have developed plugs such as Hikvision camera with controls, data analysis module and Echart.
    https://ibb.co/chMH4tm
    https://ibb.co/KDwXmxq
    in reply to: scheme editor #8892
    Zeus
    hi,
    i have tried to solve but there are still many problem. hope you can develop it in scheme editor
    https://ibb.co/Tkg8LSw
    in reply to: 65535 limit #8888
    Zeus
    I got a problem. I am trying to config input channels. The type of channel is calculated real. I checked event and event onchange. But there is no event triggered on the webstation.
    https://ibb.co/fdq9tfg
    the count of input channels is 19900. whether or not it is the reason that caused the problem.
    in reply to: scheme editor #8878
    Zeus
