Zeus
Viewing 15 posts - 46 through 60 (of 165 total)
  • in reply to: ScadaClient.GetSlice #12021
    Zeus
    I use influxdb storage history data.
    I can use api GetTrend and GetCurrentData get data from influx.
    When i use getslice
    ScadaClient.GetSlice(ArchiveBit.Minute, DateTime.UtcNow.AddMinute(-1), new int[] { 101 })
    it returns scadadata undefined stat 0 val 0
    the influxdb has cnl 101’s data every secend.
    If i want to get cnl 101’s data at “DateTime.UtcNow.AddMinute(-1)”. how can i make it?
    in reply to: ScadaClient.GetSlice #12013
    Zeus
    I save data into influxdb per secend.
    How can i get cnl data an hour ago.
    in reply to: config fie upload #12003
    Zeus
    It works excellent
    in reply to: config fie upload #11999
    Zeus
    I use ExtDepPostgreSql to storage config.
    So the config files won’t written into the directory.
    The config info in directory and sql are different.
    The server and comm start up with the config in file but not sql.
    How to config it to make it right?
    in reply to: config fie upload #11998
    Zeus
    There is nothing special in log fie
    Config file is below
    <ScadaAgentConfig>
    <ListenerOptions>
    <Port>10002</Port>
    <Timeout>10000</Timeout>
    <SecretKey>0E063D581B1DB27B8E984993DED65CE99284A706756C706C7F3B12C44BD55D4D</SecretKey>
    </ListenerOptions>
    <ReverseConnection enabled=”false”>
    <Name>Reverse Connection</Name>
    <Host>localhost</Host>
    <Port>10002</Port>
    <Username>ScadaAgent</Username>
    <Password>B9D0F030265751578B00E9801C69320C</Password>
    <Instance>Default</Instance>
    </ReverseConnection>
    <Instances>
    <Instance active=”true” name=”Default”>
    <ProxyMode>false</ProxyMode>
    <Directory>/data/scada/</Directory>
    <AdminUser>
    <Username>ScadaAdmin</Username>
    </AdminUser>
    </Instance>
    <Instance active=”false” name=”Remote Site”>
    <ProxyMode>true</ProxyMode>
    <AdminUser>
    </AdminUser>
    <AgentUser>
    </AgentUser>
    </Instance>
    </Instances>
    </ScadaAgentConfig>
    in reply to: config fie upload #11991
    Zeus
    I tried it and it do not work. there won’t be new file. The directory is empty
    in reply to: config fie upload #11981
    Zeus
    I did not get any error in log file.
    I test it in a new ubuntu 20.04.
    It could not override the old config files in the config directory.
    the user and group is both root and the permissions is 777
    in reply to: DrvDsOpcUaServer BUG #11764
    Zeus
    in reply to: scada v6 archive error #11593
    Zeus
    My archive config is like this
    <Archives>
    <Archive active=”true” code=”Cur” name=”Current Data” kind=”Current” module=”ModArcInfluxDb”>
    <Option name=”FlushPeriod” value=”30″ />
    <Option name=”LogEnabled” value=”false” />
    <Option name=”ReadOnly” value=”false” />
    <Option name=”UseCopyDir” value=”true” />
    </Archive>
    <Archive active=”true” code=”Min” name=”Minute Archive” kind=”Historical” module=”ModArcInfluxDb”>
    <Option name=”Connection” value=”” />
    <Option name=”IsPeriodic” value=”true” />
    <Option name=”PullToPeriod” value=”0″ />
    <Option name=”Retention” value=”365″ />
    <Option name=”WriteWithPeriod” value=”true” />
    <Option name=”WritingPeriod” value=”1″ />
    <Option name=”WritingPeriodUnit” value=”Minute” />
    </Archive>
    <Archive active=”true” code=”Hour” name=”Hourly Archive” kind=”Historical” module=”ModArcInfluxDb”>
    </Archive>
    <Archive active=”false” code=”Day” name=”Daily archive” kind=”Historical” module=”ModArcBasic”>
    <Option name=”UseCopyDir” value=”false” />
    <Option name=”WritingMode” value=”AutoWithPeriod” />
    <Option name=”WritingPeriod” value=”24″ />
    <Option name=”WritingUnit” value=”Hour” />
    </Archive>
    <Archive active=”true” code=”Events” name=”Event Archive” kind=”Events” module=”ModArcInfluxDb”>
    </Archive>
    <Archive active=”true” code=”CurCopy” name=”Current Data” kind=”Current” module=”ModArcPostgreSql”>
    <Option name=”MaxQueueSize” value=”1000″ />
    <Option name=”UseStorageConn” value=”true” />
    </Archive>
    <Archive active=”true” code=”MinCopy” name=”Minute Archive” kind=”Historical” module=”ModArcPostgreSql”>
    <Option name=”PartitionSize” value=”OneMonth” />
    <Option name=”WritingUnit” value=”Minute” />
    </Archive>
    <Archive active=”true” code=”HourCopy” name=”Hourly Archive” kind=”Historical” module=”ModArcPostgreSql”>
    </Archive>
    <Archive active=”false” code=”DayCopy” name=”Daily archive copy” kind=”Historical” module=”ModArcPostgreSql”>
    </Archive>
    <Archive active=”true” code=”EventsCopy” name=”Event Archive” kind=”Events” module=”ModArcPostgreSql”>
    </Archive>
    </Archives>
    • This reply was modified 3 years, 10 months ago by Zeus.
    in reply to: scada v6 archive error #11592
    Zeus
    the other file could be transfer right
    in reply to: scada v6 archive error #11546
    Zeus
    there is no error in log file
    in reply to: scada v6 archive error #11527
    Zeus
    upload project could not upload file in scadaserver/config
    in reply to: scada v6 archive error #11526
    Zeus
    postgres and influxdb archive error
    in reply to: API to access server comm line device status #11193
    Zeus
    If we have many SCADA installed in different computers. I want to know the status of Servers and Comms.
    in reply to: communicator question #11178
    Zeus
    Thanks i see.
