mark9966
Viewing 13 posts - 1 through 13 (of 13 total)
  • in reply to: Windows server 2019 VM server is unvailable #7725
    mark9966
    What in ScadaServer.log?
    I have no log files other than in the ScadaWeb folder, is this possible? all Log folders are empty except for C:\SCADA\ScadaWeb\log and what showed below. What can the problem be?
    2020-12-11 16:33:21 <INSTANCE-4><DefaultAppPool><ACT> Initialize common web application data
    2020-12-11 16:33:21 <INSTANCE-4><DefaultAppPool><ACT> Connect to SCADA-Server “localhost”
    2020-12-11 16:33:22 <INSTANCE-4><DefaultAppPool><EXC> Error connecting to SCADA-Server: No connection could be made because the target machine actively refused it 127.0.0.1:10000
    2020-12-11 16:33:22 <INSTANCE-4><DefaultAppPool><ACT> Disconnect from SCADA-Server
    2020-12-11 16:33:22 <INSTANCE-4><DefaultAppPool><EXC> Error refreshing the tables of the configuration database:
    Scada.ScadaException: Unable to receive the configuration database modification time.
    at Scada.Client.DataCache.RefreshBaseTables()
    2020-12-11 16:33:26 <INSTANCE-4><DefaultAppPool><ACT> User information has been added. IP address: ::1. Session: sd5thkccmsit3analnrcpmym
    2020-12-11 16:33:31 <INSTANCE-4><DefaultAppPool><ERR> Unable to connect to SCADA-Server. Try again.
    2020-12-11 16:33:31 <INSTANCE-4><DefaultAppPool><EXC> Error refreshing the tables of the configuration database:
    2020-12-11 16:33:31 <INSTANCE-4><DefaultAppPool><ERR> Unsuccessful login attempt: admin – Server is unavailable. IP address: ::1
    2020-12-11 16:35:56 <INSTANCE-4><DefaultAppPool><ACT> Connect to SCADA-Server “localhost”
    2020-12-11 16:35:57 <INSTANCE-4><DefaultAppPool><EXC> Error connecting to SCADA-Server: No connection could be made because the target machine actively refused it 127.0.0.1:10000
    2020-12-11 16:35:57 <INSTANCE-4><DefaultAppPool><ACT> Disconnect from SCADA-Server
    2020-12-11 16:35:57 <INSTANCE-4><DefaultAppPool><EXC> Error refreshing the tables of the configuration database:
    2020-12-11 16:35:57 <INSTANCE-4><DefaultAppPool><ACT> User information has been added. IP address: 127.0.0.1. Session: rvwcnr2dnz133hwtho02dffa
    2020-12-11 16:36:03 <INSTANCE-4><DefaultAppPool><ERR> Unable to connect to SCADA-Server. Try again.
    2020-12-11 16:36:03 <INSTANCE-4><DefaultAppPool><EXC> Error refreshing the tables of the configuration database:
    2020-12-11 16:36:03 <INSTANCE-4><DefaultAppPool><ERR> Unsuccessful login attempt: admin – Server is unavailable. IP address: 127.0.0.1
    2020-12-11 16:36:28 <INSTANCE-4><DefaultAppPool><ACT> Connect to SCADA-Server “localhost”
    2020-12-11 16:36:29 <INSTANCE-4><DefaultAppPool><EXC> Error connecting to SCADA-Server: No connection could be made because the target machine actively refused it 127.0.0.1:10000
    2020-12-11 16:36:29 <INSTANCE-4><DefaultAppPool><ACT> Disconnect from SCADA-Server
    2020-12-11 16:36:29 <INSTANCE-4><DefaultAppPool><EXC> Error refreshing the tables of the configuration database:
    2020-12-11 16:36:29 <INSTANCE-4><DefaultAppPool><ACT> User information has been added. IP address: 34.122.105.138. Session: fwv13doqtao3s14sq23lwvl0
    2020-12-11 16:45:47 <INSTANCE-4><DefaultAppPool><ACT> User information has been removed. IP address: 127.0.0.1. Session: rvwcnr2dnz133hwtho02dffa
    2020-12-11 16:45:47 <INSTANCE-4><DefaultAppPool><ACT> User information has been removed. IP address: 34.122.105.138. Session: fwv13doqtao3s14sq23lwvl0
    2020-12-11 16:45:47 <INSTANCE-4><DefaultAppPool><ACT> User information has been removed. IP address: ::1. Session: sd5thkccmsit3analnrcpmym
    2020-12-11 16:45:47 <INSTANCE-4><DefaultAppPool><ACT> Application shutdown
    2020-12-14 14:40:30 <INSTANCE-4><DefaultAppPool><ACT> Initialize common web application data
    2020-12-14 14:40:30 <INSTANCE-4><DefaultAppPool><ACT> Connect to SCADA-Server “localhost”
    2020-12-14 14:40:31 <INSTANCE-4><DefaultAppPool><EXC> Error connecting to SCADA-Server: No connection could be made because the target machine actively refused it 127.0.0.1:10000
    2020-12-14 14:40:31 <INSTANCE-4><DefaultAppPool><ACT> Disconnect from SCADA-Server
    2020-12-14 14:40:31 <INSTANCE-4><DefaultAppPool><EXC> Error refreshing the tables of the configuration database:
    2020-12-14 14:40:31 <INSTANCE-4><DefaultAppPool><ACT> User information has been added. IP address: ::1. Session: 2nvstsgnbfhbftscd3dt1f0y
    2020-12-14 14:40:40 <INSTANCE-4><DefaultAppPool><ACT> Connect to SCADA-Server “localhost”
    2020-12-14 14:40:41 <INSTANCE-4><DefaultAppPool><EXC> Error connecting to SCADA-Server: No connection could be made because the target machine actively refused it 127.0.0.1:10000
    2020-12-14 14:40:41 <INSTANCE-4><DefaultAppPool><ACT> Disconnect from SCADA-Server
    2020-12-14 14:40:41 <INSTANCE-4><DefaultAppPool><EXC> Error refreshing the tables of the configuration database:
    2020-12-14 14:40:41 <INSTANCE-4><DefaultAppPool><ERR> Unable to connect to SCADA-Server. Try again.
    2020-12-14 14:40:41 <INSTANCE-4><DefaultAppPool><ERR> Unsuccessful login attempt: admin – Server is unavailable. IP address: ::1
    in reply to: Windows server 2019 VM server is unvailable #7715
    mark9966
    I have nothing since it is a new VM on gcp which has installed only rapid scada. I do not have anything on server log except of log in scadaweb tha i showed. What can i do? i tried to reinstall it but it seems not everything runs (at least no agent).
    in reply to: HTTPS endpoint #7714
    mark9966
    No it doesn’t.
    in reply to: HTTPS endpoint #7704
    mark9966
    Tried that solution but both trying local and public access goes to error https://postimg.cc/gnQRMb5F. What am i missing?
    in reply to: Windows server 2019 VM server is unvailable #7703
    mark9966
    Inside ScadaWeb log
    2020-12-07 12:43:37 <INSTANCE-4><DefaultAppPool><ACT> Initialize common web application data
    2020-12-07 12:43:37 <INSTANCE-4><DefaultAppPool><ACT> Connect to SCADA-Server “localhost”
    2020-12-07 12:43:38 <INSTANCE-4><DefaultAppPool><EXC> Error connecting to SCADA-Server: No connection could be made because the target machine actively refused it 127.0.0.1:10000
    2020-12-07 12:43:38 <INSTANCE-4><DefaultAppPool><ACT> Disconnect from SCADA-Server
    2020-12-07 12:43:38 <INSTANCE-4><DefaultAppPool><EXC> Error refreshing the tables of the configuration database:
    2020-12-07 12:43:41 <INSTANCE-4><DefaultAppPool><ACT> User information has been added. IP address: 93.70.86.159. Session: 4tnsyzmb4n05etxvagb2irj0
    2020-12-07 12:43:47 <INSTANCE-4><DefaultAppPool><ERR> Unable to connect to SCADA-Server. Try again.
    2020-12-07 12:43:47 <INSTANCE-4><DefaultAppPool><EXC> Error refreshing the tables of the configuration database:
    2020-12-07 12:43:47 <INSTANCE-4><DefaultAppPool><ERR> Unsuccessful login attempt: admin – Server is unavailable. IP address: 93.70.86.159
    2020-12-07 12:46:29 <INSTANCE-4><DefaultAppPool><ACT> Connect to SCADA-Server “localhost”
    2020-12-07 12:46:30 <INSTANCE-4><DefaultAppPool><EXC> Error connecting to SCADA-Server: No connection could be made because the target machine actively refused it 127.0.0.1:10000
    2020-12-07 12:46:30 <INSTANCE-4><DefaultAppPool><ACT> Disconnect from SCADA-Server
    2020-12-07 12:46:30 <INSTANCE-4><DefaultAppPool><EXC> Error refreshing the tables of the configuration database:
    2020-12-07 12:46:30 <INSTANCE-4><DefaultAppPool><ACT> User information has been added. IP address: ::1. Session: f0e4iwlzffopurbcu2tt2e15
    2020-12-07 12:46:40 <INSTANCE-4><DefaultAppPool><ACT> Connect to SCADA-Server “localhost”
    2020-12-07 12:46:41 <INSTANCE-4><DefaultAppPool><EXC> Error connecting to SCADA-Server: No connection could be made because the target machine actively refused it 127.0.0.1:10000
    2020-12-07 12:46:41 <INSTANCE-4><DefaultAppPool><ACT> Disconnect from SCADA-Server
    2020-12-07 12:46:41 <INSTANCE-4><DefaultAppPool><EXC> Error refreshing the tables of the configuration database:
    2020-12-07 12:46:41 <INSTANCE-4><DefaultAppPool><ERR> Unable to connect to SCADA-Server. Try again.
    2020-12-07 12:46:41 <INSTANCE-4><DefaultAppPool><ERR> Unsuccessful login attempt: admin – Server is unavailable. IP address: ::1
    2020-12-07 13:00:45 <INSTANCE-4><DefaultAppPool><ACT> User information has been removed. IP address: 93.70.86.159. Session: 4tnsyzmb4n05etxvagb2irj0
    2020-12-07 13:00:45 <INSTANCE-4><DefaultAppPool><ACT> User information has been removed. IP address: ::1. Session: f0e4iwlzffopurbcu2tt2e15
    2020-12-07 13:00:45 <INSTANCE-4><DefaultAppPool><ACT> Application shutdown
    2020-12-09 10:24:24 <INSTANCE-4><DefaultAppPool><ACT> Initialize common web application data
    2020-12-09 10:24:25 <INSTANCE-4><DefaultAppPool><ACT> Connect to SCADA-Server “localhost”
    2020-12-09 10:24:26 <INSTANCE-4><DefaultAppPool><EXC> Error connecting to SCADA-Server: No connection could be made because the target machine actively refused it 127.0.0.1:10000
    2020-12-09 10:24:26 <INSTANCE-4><DefaultAppPool><ACT> Disconnect from SCADA-Server
    2020-12-09 10:24:26 <INSTANCE-4><DefaultAppPool><EXC> Error refreshing the tables of the configuration database:
    2020-12-09 10:24:27 <INSTANCE-4><DefaultAppPool><ACT> User information has been added. IP address: 93.70.86.159. Session: mk1a2phyybzvrjdegdgh3ct1
    2020-12-09 10:24:32 <INSTANCE-4><DefaultAppPool><ERR> Unable to connect to SCADA-Server. Try again.
    2020-12-09 10:24:32 <INSTANCE-4><DefaultAppPool><EXC> Error refreshing the tables of the configuration database:
    2020-12-09 10:24:32 <INSTANCE-4><DefaultAppPool><ERR> Unsuccessful login attempt: admin – Server is unavailable. IP address: 93.70.86.159
    2020-12-09 10:46:20 <INSTANCE-4><DefaultAppPool><ACT> User information has been removed. IP address: 93.70.86.159. Session: mk1a2phyybzvrjdegdgh3ct1
    2020-12-09 10:46:49 <INSTANCE-4><DefaultAppPool><ACT> Application shutdown
    in reply to: Windows server 2019 VM server is unvailable #7702
    mark9966
    i’ve tried to check all SCADA\*.log for allt the applications but everi Log folder is empty so i don’t know how i get the “server is unavailable” error.
    What can i do?
    in reply to: Server is unavailable #7679
    mark9966
    in reply to: Server is unavailable #7678
    mark9966
    Good morning,
    I have installed rapid scada on my win10 local machine and everything works. Then to have it accessible via internet i installe it on a windows server 2019 google cloud VM. When i try to login –> server is unavailable. No log file on the agent.
    How can i fix this?
    in reply to: HTTPS endpoint #7677
    mark9966
    Good morning,
    At the moment i need to enable it on WIn.
    in reply to: Integration with IAP #7675
    mark9966
    2) There is a plugin for automatic login. But it uses only 1 user name. To map between users, a new plugin should be developed.
    How does that work? i mean how can i develop/change it in order to achieve what i need? i mean if i put an Identity Aware Proxy in front maybe we can extract the user and then use the autologin, but idk how does that work right now and if will be able to modify it.
    in reply to: Integration with IAP #7651
    mark9966
    Good morning,
    is there a way to enable https? windows and or linux? how? cause i need an https endpoint.
    thanks.
    in reply to: Integration with IAP #7638
    mark9966
    Good morning,
    i’m running it on gcp linux VM to be accessible via web.
    Identity aware proxy is a way of adding a protection layer on a service, in this case rapidSCADA. In my project what i need to achieve is to protect both remote and local access to the SCADA.
    I’ve seen that it is protected by login, i have some question:
    1) user management can associate different functions to different roles? i mean admin can input values other users can not.
    2) if i’m putting a IAP in front which have login as well, may i be able to login automatically with that user? i mean a mapping between those users and the one inside rapidSCADA, idk maybe a component which take that credentials and do the login (how would you do that?) both remote and local accesses
    3) linux version have the graphical interface? it supports https?
    Thanks a lot!
    in reply to: Integration with IAP #7622
    mark9966
    adding:
    5) how can i settle both external and local (with and without LAN) accesses?
