zzz
Viewing 15 posts - 76 through 90 (of 165 total)
  • in reply to: v6, DrvDsInfluxDB suport InfluxDB or InfluxDB2 or both ? #11474
    zzz
    Figured out, all channels’s archive mask needs to be updated in channel db.
    Issue closed.
    in reply to: v6, DrvDsMqtt not publishing anything. #11472
    zzz
    For the ds1 box which runs the Hello world project, after being left there a day, after a simple restart I have log and mqtt message working suddently.
    2022-11-02 20:48:06 Send Communicator/line001/device001/RA = [8.23553587241761, 1.7859521750263974, 8.98281170950074]
    2022-11-02 20:48:07 Send Communicator/line001/device001/Sin = -0.9474630312854811
    2022-11-02 20:48:07 Send Communicator/line001/device001/Tri = 11.89087025833328
    2022-11-02 20:48:07 Send Communicator/line001/device001/RA = [3.225585997960694, 7.005090602011139, 0.8210334274466347]
    2022-11-02 20:48:08 Send Communicator/line001/device001/Sin = -0.9468726164272638
    2022-11-02 20:48:08 Send Communicator/line001/device001/Sqr = 1
    2022-11-02 20:48:08 Send Communicator/line001/device001/Tri = 11.8732918
    1667393441: Received PUBLISH from esp_rs6a (d0, q0, r0, m0, 'Communicator/line001/device001/RA', ... (59 bytes))
    1667393442: Received PUBLISH from esp_rs6a (d0, q0, r0, m0, 'Communicator/line001/device001/Sin', ... (19 bytes))
    1667393442: Received PUBLISH from esp_rs6a (d0, q0, r0, m0, 'Communicator/line001/device001/Tri', ... (17 bytes))
    1667393442: Received PUBLISH from esp_rs6a (d0, q0, r0, m0, 'Communicator/line001/device001/RA', ... (57 bytes))
    1667393443: Received PUBLISH from esp_rs6a (d0, q0, r0, m0,
    But for the server, that I have regain access to, which connect to real devices and has more registers, the problem persists.
    Is there anything else that I haven’t thought of ? (e.g. I have figured out the InfluxDB stuff, its b/c 77 channels are not bound to the archive one by one)
    The detailed log doesn’t offer much which is why I resolved to mosquitto log. Below is the detailed log you requested:
    2022-11-02 20:21:42 MQTT data source started
    2022-11-02 20:21:42 Connect to 127.0.0.1:1883
    Connected successfully
    2022-11-02 20:21:42 Subscribe to command topic
    2022-11-02 20:28:54 Disconnect from 127.0.0.1:1883
    2022-11-02 20:28:54 MQTT data source stopped
    2022-11-02 20:29:06 MQTT data source started
    2022-11-02 20:29:06 Connect to 127.0.0.1:1883
    2022-11-02 20:29:06 Subscribe to command topic
    2022-11-02 20:45:42 Disconnect from 127.0.0.1:1883
    2022-11-02 20:45:43 MQTT data source stopped
    2022-11-02 20:45:55 MQTT data source started
    2022-11-02 20:45:55 Connect to 127.0.0.1:1883
    2022-11-02 20:45:55 Subscribe to command topic
    The mosquitto log only have PINGREQ/RSP stuff, not gonna repeat it here.
    The Communicator setting on server is basically identical to the box running helloworld project. I think there is something else I am missed, what could that be?
    working copy in hello world project
        <DataSource active="true" code="MqttPublish" name="Mqtt Publish" driver="DrvDsMqtt">
          <Option name="ClientID"     value="esp_rs6a" />
          <Option name="DataLifetime" value="60" />
          <Option name="DetailedLog"  value="True" />
          <Option name="DeviceFilter" value="" />
          <Option name="MaxQueueSize" value="1000" />
          <Option name="Password"     value="C8080E774B59B0C6694063BDE2428352" />
          <Option name="Port"         value="1883" />
          <Option name="ProtocolVersion" value="Unknown" />
          <Option name="PublishFormat" value="" />
          <Option name="QosLevel"     value="0" />
          <Option name="Retain"       value="False" />
          <Option name="RootTopic"    value="Communicator/" />
          <Option name="Server"       value="127.0.0.1" />
          <Option name="Timeout"      value="10000" />
          <Option name="UndefinedValue" value="NaN" />
          <Option name="Username"     value="esp_rs6a" />
        </DataSource>
    problematic server
        <DataSource active="true" code="MqttServer" name="Mqtt Publish" driver="DrvDsMqtt">
          <Option name="ClientID"     value="esp_rs6" />
          <Option name="Username"      value="esp_rs6" />
        </DataSource>
    • This reply was modified 3 years, 11 months ago by zzz.
    in reply to: v6, DrvDsMqtt not publishing anything. #11468
    zzz
    If it works, it should look sth. like below.
    root# mosquitto -v -c /etc/mosquitto/mosquitto.conf
    1667213406: Loading config file /etc/mosquitto/conf.d/log+cache.conf
    1667213406: Loading config file /etc/mosquitto/conf.d/remote-p1883.conf
    1667213406: mosquitto version 2.0.11 starting
    1667213406: Config loaded from /etc/mosquitto/mosquitto.conf.
    1667213406: Opening ipv4 listen socket on port 1883.
    1667213406: mosquitto version 2.0.11 running
    1667213407: New connection from 127.0.0.1:59420 on port 1883.
    1667213407: New client connected from 127.0.0.1:59420 as esp_debug (p2, c1, k60, u'esp_debug').
    1667213407: No will message specified.
    1667213407: Sending CONNACK to esp_debug (0, 0)
    1667213407: Received SUBSCRIBE from esp_debug
    1667213407:     # (QoS 0)
    1667213407: esp_debug 0 #
    1667213407: Sending SUBACK to esp_debug
    1667213409: Received PUBLISH from esp_debug (d0, q0, r0, m0, 'Communicator/test', ... (17 bytes))
    1667213409: Sending PUBLISH to esp_debug (d0, q0, r0, m0, 'Communicator/test', ... (17 bytes))
    client_id esp_debug is publishing a 17 bytes long message to topic Communicator/test
    in reply to: v6, DrvDsInfluxDB suport InfluxDB or InfluxDB2 or both ? #11461
    zzz
    I am not exactly sure how that is supposed to be done.
    But in the helloworld project on a different box, it works correctly after I added connection setting and configured minute copy archive to use influxdb.
    And I can see below message in log now. I guess that mean it working.
    I will double check my previous instance setup after I regain access to the server.
    2022-10-30 16:05:30 Successful response from the database server
    2022-10-30 16:05:45 Writing of 8 data points completed successfully in 0 ms
    2022-10-30 16:05:45 Successful response from the database server
    2022-10-30 16:06:00 Writing of 8 data points completed successfully in 0 ms
    2022-10-30 16:06:00 Successful response from the database server
    I have some question, why not current data?
    What does read only option mean ?
    Can I disable file backends if I use influx?
    in reply to: v6, DrvDsMqtt not publishing anything. #11457
    zzz
    I lost access to my previous instance due to power outage. Just re-setup a new one, this time the Hello World project from repo/Project folder is used. MqttDsDrv is enabled. The output from broker is similar.
    1667115000: Loading config file /etc/mosquitto/conf.d/remote-p1883.conf
    1667115000: mosquitto version 2.0.11 starting
    1667115000: Config loaded from /etc/mosquitto/mosquitto.conf.
    1667115000: Opening ipv4 listen socket on port 1883.
    1667115000: mosquitto version 2.0.11 running
    1667115001: New connection from 127.0.0.1:35846 on port 1883.
    1667115001: New client connected from 127.0.0.1:35846 as esp_rs6a (p2, c1, k15, u'esp_rs6a').
    1667115001: No will message specified.
    1667115001: Sending CONNACK to esp_rs6a (0, 0)
    1667115001: Received SUBSCRIBE from esp_rs6a
    1667115001:     Communicator/command (QoS 2)
    1667115001: esp_rs6a 2 Communicator/command
    1667115001: Sending SUBACK to esp_rs6a
    1667115016: Received PINGREQ from esp_rs6a
    1667115016: Sending PINGRESP to esp_rs6a
    1667115031: Received PINGREQ from esp_rs6a
    1667115031: Sending PINGRESP to esp_rs6a
    To get mosquitto to output the above message in console,
    I forgot one thing:
    log_dest stderr must but be put into the config file e.g.
    /etc/mosquitto/conf.d/console_test.conf
    log_dest stderr
    listener 1883 127.0.0.1
    protocol mqtt
    allow_anonymous true
    persistence false
    Also mosquitto service must be stopped before running mosquitto in console.
    Or mosquitto will not start and gives no error message.
    systemctrl stop mosqiutto
    • This reply was modified 3 years, 12 months ago by zzz.
    in reply to: How to configure Archive? #11454
    zzz
    I reserve my reply before I finish checking out these v6 features 🙂
    in reply to: v6, DrvDsMqtt not publishing anything. #11453
    zzz
    I think its working. The basic aspects of v6 work as expected now. Data polled from plc, and I can view minute data plot of all 77 channels for the last 2 days in webstation. It’s just that I didn’t notice any activity in mqtt broker.
    Again I recommend giving Mqtt Exploer a try. By default it subscribes to server root(#), all topics are visible in a clean tree. It also allows for charting of values in JSON payloads in just a few clicks. Very nice for debugging and server topics exploring.
    in reply to: v6, timezone issue #11452
    zzz
    Thank you. I grabbed the docs. Will give a closer look tomorrow.
    in reply to: V6, communicator ignores bound channel of integer data type #11446
    zzz
    That is kinda confusing, maybe it should be highlighted in the document regarding these data types, “hey users, these data types are determined by driver developers, not you, go read the driver manual.” 🙂
    • This reply was modified 4 years ago by zzz.
    in reply to: v6, DrvDsInfluxDB suport InfluxDB or InfluxDB2 or both ? #11441
    zzz
    some more info
    from ScadaServer.txt
    2022-10-27 14:09:44 [wsta][appstack][ACT] Archive Cur initialized successfully
    2022-10-27 14:09:44 [wsta][appstack][ACT] Archive Min initialized successfully
    2022-10-27 14:09:44 [wsta][appstack][ACT] Archive Hour initialized successfully
    2022-10-27 14:09:44 [wsta][appstack][ACT] Archive Events initialized successfully
    2022-10-27 14:09:44 [wsta][appstack][ACT] Archive MinCopy initialized successfully
    2022-10-27 14:09:44 [wsta][appstack][ACT] Start listener on port 10000
    2022-10-27 14:09:44 [wsta][appstack][INF] Archive in DAT format: /app/appstack/rapidscada6/Linux/scada/Archive
    2022-10-27 14:09:44 [wsta][appstack][INF] Archive copy in DAT format: /app/appstack/rapidscada6/Linux/scada/ArchiveCopy
    2022-10-27 14:09:44 [wsta][appstack][ACT] Delete outdated data from the Min archive older than 27/10/2021
    2022-10-27 14:09:44 [wsta][appstack][ACT] Delete outdated data from the Hour archive older than 27/10/2021
    2022-10-27 14:09:44 [wsta][appstack][ACT] Delete outdated data from the Events archive older than 27/10/2021
    2022-10-27 14:09:46 [wsta][appstack][ACT] Session with ID 5923217496133782260 created
    2022-10-27 14:09:46 [wsta][appstack][ACT] Client 127.0.0.1 connected
    2022-10-27 14:09:46 [wsta][appstack][ACT] Session with ID -346220670448517208 created
    2022-10-27 14:09:46 [wsta][appstack][ACT] User ScadaWeb is successfully authenticated
    from ScadaServer/Config/ScadaServerConfig.xml
      <Modules>
        <Module code="ModArcBasic" />
        <Module code="ModArcPostgreSql" />
        <Module code="ModArcInfluxDb" />
      </Modules>
      <Archives>
        <Archive active="true"
                 code="Cur"
                 name="Current data"
                 kind="Current"
                 module="ModArcBasic">
          <Option name="FlushPeriod" value="30" />
          <Option name="LogEnabled"  value="false" />
          <Option name="ReadOnly"    value="false" />
          <Option name="UseCopyDir"  value="false" />
        </Archive>
                 code="Min"
                 name="30s archive"
                 kind="Historical"
          <Option name="IsPeriodic"   value="true" />
          <Option name="PullToPeriod" value="0" />
          <Option name="Retention"    value="365" />
          <Option name="WriteWithPeriod"   value="true" />
          <Option name="WritingPeriod"     value="30" />
          <Option name="WritingPeriodUnit" value="Second" />
        </Archive>
        <Archive active="false"
                 code="CurCopy"
                 name="Current data copy"
                 kind="Current"
                 module="ModArcPostgreSql">
          <Option name="Connection"    value="" />
          <Option name="UseStorageConn" value="true" />
        </Archive>
        <Archive active="true" code="MinCopy"
                 name="Minute archive copy"
                 kind="Historical"
                 module="ModArcInfluxDb">
          <Option name="Connection"     value="local-v2" />
          <Option name="LogEnabled"     value="true" />
          <Option name="WritingPeriod"  value="1" />
          <Option name="WritingPeriodUnit"   value="Minute" />
        </Archive>
    from ScadaServer/Config/ModArcInfluxDb.xml
    <ModArcInfluxDb>
      <Connections>
        <Connection>
          <Name>     local-v2</Name>
          <Url>      http://127.0.0.1:8086</Url>
          <Token>    %token%</Token>
          <Username> %user%</Username>
          <Password> %pass%</Password>
          <Bucket>   default</Bucket>
          <Org>      default</Org>
        </Connection>
      </Connections>
    </ModArcInfluxDb>
    in reply to: v6, DrvDsInfluxDB suport InfluxDB or InfluxDB2 or both ? #11440
    zzz
    I am using InfluxDB2 local install, All I get from the log is “writing 0 data point”, why ?
    All channel data are of type Double, format Off-On.
    File Archive works fine, in webstation,
    I can open the channel’s minute data plot from table view.
    2022-10-27 14:10:00 Writing of 0 data points completed successfully in 84 ms
    2022-10-27 14:10:01 Successful response from the database server
    2022-10-27 14:11:00 Writing of 0 data points completed successfully in 1 ms
    2022-10-27 14:11:00 Successful response from the database server
    2022-10-27 14:12:00 Writing of 0 data points completed successfully in 0 ms
    2022-10-27 14:12:00 Successful response from the database server
    2022-10-27 14:13:00 Writing of 0 data points completed successfully in 0 ms
    2022-10-27 14:13:00 Successful response from the database server
    2022-10-27 14:14:00 Writing of 0 data points completed successfully in 0 ms
    2022-10-27 14:14:01 Successful response from the database server
    2022-10-27 14:15:00 Writing of 0 data points completed successfully in 0 ms
    2022-10-27 14:15:01 Successful response from the database server
    2022-10-27 14:16:00 Writing of 0 data points completed successfully in 0 ms
    2022-10-27 14:16:00 Successful response from the database server
    2022-10-27 14:17:00 Writing of 0 data points completed successfully in 0 ms
    2022-10-27 14:17:00 Successful response from the database server
    2022-10-27 14:18:00 Writing of 0 data points completed successfully in 0 ms
    2022-10-27 14:18:00 Successful response from the database server
    2022-10-27 14:19:00 Writing of 0 data points completed successfully in 0 ms
    2022-10-27 14:19:00 Successful response from the database server
    2022-10-27 14:20:00 Writing of 0 data points completed successfully in 0 ms
    2022-10-27 14:20:00 Successful response from the database server
    2022-10-27 14:21:00 Writing of 0 data points completed successfully in 0 ms
    in reply to: Buid Rapid SCADA 6 on Visual Studio Code #11438
    zzz
    Yeah, I wrote a script for that. But I noticed that some files are missing from the build output. e.g.
    web.confg
    some output are not shown in released file
    ScadaCommonApp
    ScadaCommon
    ScadaServerApp
    ScadaServer
    AgentClient.dll
    etc.
    ScadaCommon.dll
    ScadaCommon.Log.dll
    *Storage.dll
    are copied multiple times, I tried put them in one ScadaCommon folder, and add --additionalprobingpath $SCADA_COMMON after dotnet in ExecStart line, this switch works for dotnet dlls, but not all dlls e.g. MQTTNet.dll
    If the dependencies are in a central place, with some additionalprobingpath logic in code, maybe packaging could be a lot easier.
    in reply to: v6, DrvDsMqtt not publishing anything. #11436
    zzz
    Does this send any channel data ?
    or only listens for command on Communicator/Command ?
    If it listens for command only, maybe I can check if the command works?
    But how should I issue any command over DsDrvMqtt ?
    Just a side note,
    4.7.1.1 Topic level separator
    The forward slash (‘/’ U+002F) is used to separate each level within a topic tree and provide a hierarchical structure to the Topic Names… Adjacent Topic level separators indicate a zero length topic level.
    Strictly speaking, Communicator/ is a sub topic of Communicator with a zero-length sub level topic ‘. Maybe the trailing “/” should be left out.
    in reply to: v6, DrvDsMqtt not publishing anything. #11435
    zzz
    Maybe this is also related ?
      <GeneralOptions>
        <IsBound>                   true</IsBound>
        <SendModifiedData>          false</SendModifiedData>
        <SendAllDataPeriod>         60</SendAllDataPeriod>
        <EnableCommands>            true</EnableCommands>
        <EnableFileCommands>        true</EnableFileCommands>
        <StartLinesOnCommand>       false</StartLinesOnCommand>
        <MaxLogSize>                1</MaxLogSize>
      <GeneralOptions>
    in reply to: v6, DrvDsMqtt not publishing anything. #11434
    zzz
    I suggest try mosquitto -v -c /etc/mosquitto/mosquitto.conf
    Here is my mosquitto output
    1666794716: mosquitto version 2.0.11 starting
    1666794716: Config loaded from /etc/mosquitto/mosquitto.conf.
    1666794716: Opening ipv4 listen socket on port 1883.
    1666794716: mosquitto version 2.0.11 running
    1666795011: New connection from 127.0.0.1:37370 on port 1883.
    1666795011: New client connected from 127.0.0.1:37370 as esp_rs6 (p2, c1, k15, u'esp_rs6').
    1666795011: No will message specified.
    1666795011: Sending CONNACK to esp_rs6 (0, 0)
    1666795011: Received SUBSCRIBE from esp_rs6
    1666795011:     Communicatorcommand (QoS 2)
    1666795011: esp_rs6 2 Communicatorcommand
    1666795011: Sending SUBACK to esp_rs6
    1666795026: Received PINGREQ from esp_rs6
    1666795026: Sending PINGRESP to esp_rs6
    1666795041: Received PINGREQ from esp_rs6
    1666795041: Sending PINGRESP to esp_rs6
    1666795056: Received PINGREQ from esp_rs6
    1666795056: Sending PINGRESP to esp_rs6
    1666795071: Received PINGREQ from esp_rs6
    1666795071: Sending PINGRESP to esp_rs6
    ... PINGs only
    The configuration is identical to Mik’s above except for the ClientID, UserName.
          <Option name="DetailedLog" value="False" />
        </DataSource>
    2022-10-26 22:51:03 MQTT data source started
    2022-10-26 22:51:03 Detailed log is disabled
    2022-10-26 22:51:03 Connect to 127.0.0.1:1883
    2022-10-26 22:51:03 Subscribe to command topic
    /* restarted ScadaComm to change setting */
    2022-10-26 22:53:59 Disconnect from 127.0.0.1:1883
    2022-10-26 22:53:59 MQTT data source stopped
